One way comms over INTIP3 boards
amoreno32
Post by amoreno32 »
Does anyone know about this issue, in a Crystal configuration with INTIP3 boards for manage the internode link ABC-IP when one of the 5 INTIP3 board are present, more specific the INTIP3 of the position 0-17 in main shelf the PCX begin to generate a lot of incident #4104 and all calls from or to this node have the one way comm symptom, The node #1 is the more important backbone node in network 'cause the 90% of traffic in network pass over this node,
Have any one a clue about this issue??????
I attached the logs obtain form the boards via INFOCOLLECT tool, and the INCVISU file too
02/05/11 14:41:59 000001M|000/17/0/001|=3:4104=outgoing VPN Overflow call aborted No 3 12119
Copia de logs.zip
Copia de logs.zip
incvisu-00.txt
bibou
Re: One way comms over INTIP3 boards
Post by bibou »
TC1458 could be helpfull
bibou
Post by bibou »
Search "incident 4104" on TC0730 attached
amoreno32
Post by amoreno32 »
Thanks BIBOU I´ll check it tyhe docs and hope find a solution
Return to “Inter-Node Links”
