my alcatel 6850 can`t boot
it stops booting with the following
i can`t even boot in miniboot
please help
U-Boot 1.1.0(6.1.5.479.R01) (Jun 11 2007 - 18:34:09)
MPC8248 Reset Status: External Soft, External Hard
MPC8248 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8248 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS68xx (Kite II)
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
Device 0: Model: CF 64MB Firm: 06/07/29 Ser#: GHS3ABPCF07060400003
Type: Removable Hard Disk
Capacity: 62.5 MB = 0.0 GB (128000 x 512)
USB: scanning bus for devices...
USB device not responding, giving up (status=80000000)
0 USB Devices found
Hit any key to stop autoboot: 0
## Booting image at ff900000 ...
Image Name: miniboot-6.1.5.479.R01
Image Type: PowerPC VxWorks Kernel Image (gzip compressed)
Data Size: 796366 Bytes = 777.7 kB
Load Address: 00005000
Entry Point: 00005000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Ethernet MAC address not copied to NV RAM
Loading .text @ 0x01000000 (1225304 bytes)
Loading .rodata @ 0x0112b258 (249927 bytes)
Loading .data @ 0x011682a0 (111532 bytes)
Clearing .sbss @ 0x01183650 (1620 bytes)
Clearing .bss @ 0x01184000 (1832252 bytes)
## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.
1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x0
## Starting vxWorks at 0x01000000 ...
at
