IPMR (PIM) configuration
Hi guys,
I need to create two separate vlans(10 and 20) on omni 6855 for multicast routing.
I tried to configure four 6855 omni switches for multicast routing and so far I got just IPMS working but no luck with IPMR(PIM). I have Layer 2 switch with CCTV camera connected to trunk port of the omni 6855 in the lab.
Here is my configof the omni6855:
Welcome to the Alcatel-Lucent OmniSwitch 6000
Software Version 6.3.2.196.R01 GA, March 14, 2008.
Copyright(c), 1994-2007 Alcatel-Lucent. All Rights reserved.
OmniSwitch(TM) is a trademark of Alcatel-Lucent registered
in the United States Patent and Trademark Office.
! Stack Manager :
! Chassis :
system name omni10.10.100.1
! Configuration:
! VLAN :
ethernet-service mode vstk
vlan 1 enable name "VLAN 1"
vlan 3 enable name "VLAN 3"
vlan 10 enable name "vlan_10"
vlan 10 port default 1/23
vlan 10 port default 1/1-6
vlan 20 enable name "vlan_20"
vlan 20 port default 1/9-14
vlan 20 port default 1/24
! VLAN SL:
! IP :
ip service all
ip interface "vlan_10" address 10.10.100.1 mask 255.255.255.0 vlan 10 ifindex 1
ip interface "vlan_20" address 10.20.100.1 mask 255.255.255.0 vlan 20 ifindex 4
ip interface "vlan_1" ifindex 2
ip interface "1/1" address 10.10.250.1 mask 255.255.255.252 vlan 10 ifindex 3
ip interface "1/2" address 10.10.250.14 mask 255.255.255.252 vlan 10 ifindex 5
ip interface "1/9" address 10.20.250.1 mask 255.255.255.252 vlan 20 ifindex 3
ip interface "1/10" address 10.20.250.14 mask 255.255.255.252 vlan 20 ifindex 5
! IPX :
! IPMS :
ip multicast status enable
ip multicast vlan 10 status enable
ip multicast vlan 20 status enable
! AAA :
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
snmp security no security
snmp community map "PassagePublic" user "snmp" on
snmp station 10.10.28.33 161 "user" v1 enable
! RIP :
! OSPF :
ip load ospf
ip ospf area 0.0.0.0
ip ospf area 0.0.0.1
ip ospf interface "vlan_10"
ip ospf interface "vlan_10" area 0.0.0.0
ip ospf interface "vlan_10" status enable
ip ospf interface "vlan_20"
ip ospf interface "vlan_20" area 0.0.0.1
ip ospf interface "vlan_20" status enable
ip ospf interface "1/1"
ip ospf interface "1/1" area 0.0.0.0
ip ospf interface "1/1" status enable
ip ospf interface "1/2"
ip ospf interface "1/2" area 0.0.0.0
ip ospf interface "1/2" status enable
ip ospf interface "1/9"
ip ospf interface "1/9" area 0.0.0.1
ip ospf interface "1/9" status enable
ip ospf interface "1/10"
ip ospf interface "1/10" area 0.0.0.1
ip ospf interface "1/10" status enable
ip ospf status enable
! ISIS :
! IPv6 :
! IP multicast :
ip load pim
ip pim interface vlan_10
ip pim interface vlan_20
ip pim dense group 224.0.0.0/4
ip pim sparse status disable
ip pim dense status enable
ipv6 pim sparse status disable
ipv6 pim dense status disable
ip router router-id 10.10.100.1
ip router primary-address 10.10.100.1
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
vlan 10 802.1q 1/7
vlan 10 802.1q 1/8
vlan 20 802.1q 1/15
vlan 20 802.1q 1/16
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper pxe-support disable
! Server load balance :
! System service :
! SSH :
! VRRP :
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
I created Interfaces "1/1" and "1/2" for L3 routing and multicast for vlan 10
and
Interfaces "1/9" and "1/10" for L3 routing and multicast for vlan 20
Please, check L3 config because I'm not sure is it correct.
Thank you and best regards
Gucul
IPMR (PIM) protocol configuration
Gucul
Re: IPMR (PIM) protocol configuration
Post by Gucul »
It's my lab topology:
cedric1
Post by cedric1 »
Hello
I'm more used to with PIM-SM. And what is write here is for PIM-SM.
I assume you have ip connectivity end to end between client an multicast server.
You need to configure on one switch, where L3 is active, this :
candidate rendez-vous point (c-rp) and bootstrap router. It is mandatory !! to have both configured, so PIM info message can be exchanged in your Multicast environnment.
Or you can try to user dvmrp, more simple for small network. Enable dvmrp on each routed interface in your L3 switch and it must work
Cedric
Cedric
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
