2 oxe AND 1 4400 NETWORK
BANNAIRE
Post by BANNAIRE »
Hello alls
I have 3 nodes connected in IP Hybrid links
Node 1 STGR
Node2 Hoche
Node 3 Amaris
All in release R9.1
Everything is fine between Node 1 and Node 2
From node 3, I can call Node 1 and Node 2 without any problem. Node 3 can be called by Node 1 and Node 2 as well.
If I want to transfer a communication from Node 1 or Node 2 towards Node 3, there is no audio and I get the following message. Anybody can help ?
Thank you
(E)oxe_amaris> 15/04/11 18:53:40 000003M|001/00/-/---|=0:4412=H323 : arret de la communication avec cause 5
Re: 2 oxe AND 1 4400 NETWORK
Prefixes "PCX address in DPNSS" exist on all nodes?
BANNAIRE
Post by BANNAIRE »
Hello Vad
No I do'nt use such a prefix. The numbering of node 1 is 1xxx, node 2 is 2xxx and node 3 is 3xxx and for example in the node 1, prefix 2 and 3 are routing number in the prefix plan of the translator
For network - you need to create such prefix for each node. (f.e. A001 for N1, A002 for N2...).
F.e. without prefixes and ABC-F T2 connection (node 1and 2) - user from node 1 call to user from node 2. Called node 2 user make a transfer (to node 1 user). In trkstat we will see 2 used TS.
If prefixes exist - after transfer all TS free. This pefixes used for path optimization and so on.
BANNAIRE
Post by BANNAIRE »
Hi Vad
Sorry Vad, I never used such prefixes for networking. My netwok is OK in lab, it goes wrong throuh the VPNs
Return to “IP”
