Hi Guys,
One of our OXO's got hacked last night via the personal assistant and made a lot of overseas calls.
Does anyone have any guides for securing an oxo so it cannot be hacked?
Cheers
P
OXO Hacked
jan
Re: OXO Hacked
Hi there,
What software release is your system.From release 7 it is automatically turned off, if earlier version you have to turn it off.
Have a look at PersAssAlwd(in other labels).If you not using pers assis you should set it to 00.so 00 = pers assis off, 01= pers assis on
Good Luck.
Good Luck.
mopo
Re: OXO Hacked
yes it should be but it isn't in my list there is
PI8RingbEx
PbxDivVar
but no PerAssAlwd in between those two.
This is just one of my systems the box's with rel 7 both had PerAssAlwd as noteworthy addresses describes.
Wierd :/
PI8RingbEx
PbxDivVar
Wierd :/
mopo
Re: OXO Hacked
Ah I found out why I can't see it on my rel 6 box is 6.14 and you need at least 6.33 for this flag.
see viewtopic.php?f=73&t=7512
mopo
Re: OXO Hacked
Does anyone have the following TC in English they could send me?
Communication Technique TC1143 Ed 03 Date : 05/06/2009
Produit : Alcatel-Lucent OmniPCX Office Nb. de pages: 3
Title: Security Recommendations
I don't have access to the alcatel partner site.
et
Re: OXO Hacked
Look at the attached file.
