Alcatel to Avaya connection through H.323
hotmail911
Post by hotmail911 »
Hi,everybody. I have a question ,I hope somebody can help me ,thanks very much.
A calling number from Avaya system,B called number from Alcatel system,
Alcatel to Avaya connection through H.323,
when A Dial B, telephone conversation is ok,but A calling number cann't ring-back tone from alcatel system。
Another test,
C called number from Nortel system,Alcatel to Nortel connection through E1,
when A Dial C through alcatel system, telephone conversation is ok,ring-back tone is Ok?
alex
Re: Alcatel to Avaya connection through H.323
Post by alex »
You'd better be more specific if tou want to get some answers.
Which Alcatel PBX? Which version? Which Avaya PBX? Which version?
Who does not hear ring-back tone?
As I understand (if you use Direct RTP) when Avaya user call to Alcatel user - RTP connection will be established ONLY after answer.
Before - RTP connection absent and Avaya must generate RBT locally (after receiving "Alert" message).
hotmail911
alex thanks your Informing ,
Avaya system number cann't hear ring-back tone
Avaya PBX S8730 ,Version:R5.2.1
Alcatel PBX OXE 4400,
Version:
R6.1.1-f2.502-12-d-cn-c7
Business identification: R6.1.1
Release:
DELIVERY f2.502
Patch identification: 12
Dynamic patch identification: d
Country: cn
Cpu: c7
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
hotmail911
Thanks very much Vad,
When Direct RTP +False,The calling number 32190 from Avaya system cann'thear ring-back tone,but telephone conversation is ok。
| (726254:532159) Physical-Event :
| long: 52 desti: 0 source: 0 cryst: 0 cpl: 22 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 34
| SENDING COMPLETE
| IE:[18] CHANNEL (l=1) a3 -> T2 : Any B channel
| IE:[1e] PROGRESS_ID (l=2) 81 83
| IE:[6c] CALLING_NUMBER (l=7) -> 00 80 Num : 32190
| IE:[70] CALLED_NUMBER (l=6) -> a1 Num : 62519
| IE:[7d] HLC (l=2) 91 81
| (726254:532160) 1031: Send_IO1 (link-nbr=22, sapi=0, tei=0) :
| long: 33 desti: 0 source: 15 cryst: 0 cpl: 22 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 34
| [9f] Non-locking shift. codeset : 7
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 1 Vad 0
| IE:[07] EI_IP_QOS (l=3) 00 a0 00
| IE:[18] CHANNEL (l=3) a9 83 93 -> T2 : B channel 19 exclusive
| (726254:532161) 1031: Send_IO1 (link-nbr=22, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 0 cpl: 22 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 34
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (726256:532162) Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 0 cpl: 3 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : e9 3b
| IE:[1e] PROGRESS_ID (l=2) 80 88
| (726256:532163) 1031: Send_IO1 (link-nbr=0, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 0 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : fb a5
when Direct RTP +true,dail fail
| (727076:533571) Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 2d
| SENDING COMPLETE
| (727076:533572) 1034: Send_IO1 (link-nbr=22, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 2d
| IE:[18] CHANNEL (l=3) a8 83 81 -> T2 : No B channel
| (727076:533573) 1034: Send_IO1 (link-nbr=22, sapi=0, tei=0) :
| long: 51 desti: 0 source: 15 cryst: 0 cpl: 22 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 2d
| IE:[0a] EI_RTP_INFO (l=30)
| -> fwd=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=1 rqm=0 read_rf=0
| -> Transm_Bande=1 detection_Q23=1 dtmf_payload=96
| -> Port RTP = 32580, IPv4 : 172. 22. 253. 194.
| -> Port RTCP SR = 32581, IPv4 : 172. 22. 253. 194.
| -> Port RTCP RR = 32581, IPv4 : 172. 22. 253. 194.
| -> Port Fax = 32582, IPv4 : 172. 22. 253. 194.
| (727076:533574) 1034: Send_IO1 (link-nbr=22, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 2d
| (727076:533575) Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 0 cpl: 22 us: 0 term: 0 type a5
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 00 2d
| IE:[08] CAUSE (l=2) 81 c2 -> [c2] CHANNEL TYPE NOT IMPLEMENTED
| (727076:533576) Physical-Event :
| IE:[08] CAUSE (l=2) 81 e5 -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
| (727076:533577) Physical-Event :
i think you need to install more new patch,
f.e. from read.me (from patch 33, info about patch 29)
XTSce97590 Problem of Ring Back Tone when RTP direct is set to FALSE
Ethan
Post by Ethan »
Sorry to inform you that I am not a technician who can solve your problem but I can probably suggest that you can look for the possible solutions available online. So, look for solutions available online and get your query solved by referring to some good websites.
Return to “IP”
