What does REG and E001 0000 in dir mean?
IP and Voice over IP
krutarthap
Post by krutarthap »
When doing a listerm command, what does "REG" and "E001 0000" in dir column mean? Its quite confusing that we get a number sometimes and sometimes we get these wierd things. I expected the extension number in this column as we can see in most cases.
Thank You
Re: What does REG and E001 0000 in dir mean?
If you show listerm output - you will have more good answer
krutarthap
Thanks Vad,
Here is the listerm output you requested.
 | Coupler:19  0 Logic type: CPL_FICTIFBoard: FICTIF State: REGISTERED NOT |
 | Coupler:19  1 Logic type: INTIPA    Board: INTIPA State: IN SERVICE     |
 | Coupler:19  2 Logic type: INTIPA    Board: INTIPA State: OUT OF SERVICE |
 | Coupler:19  3 Logic type: CPL_UA    Board: UA_FIC State: IN SERVICE     |
 | Cry:Cpl:ac:term|  neqt | typ term   |  dir nb   | Out of service cause  |
 | 19   3   0   0 | 01697 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   1 | 01698 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   2 | 01699 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   3 | 01700 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   4 | 01701 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   5 | 01702 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   6 | 01703 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   7 | 01704 |    POS_NUM |  REG      |  . . . . . . . . . .  |
 | 19   3   0   8 | 01705 |   IPT 4068 |  2000     |  . . . . . . . . . .  |
 | 19   3   0   9 | 01706 |   IPT 4038 |  2001     |  . . . . . . . . . .  |
 | 19   3   0  10 | 01707 |   IPT 4068 |  5090     |  A . . . . . . . . .  |
 | Coupler:19  4 Logic type: CPL_Z     Board: Z_FICT State: IN SERVICE     |
 | 19   4   0   0 | 01443 |     AUTPOS |  E0010000 |  . . . . . . . . . .  |
 | 19   4   0   1 | 01444 |     AUTPOS |  E0010001 |  . . . . . . . . . .  |
 | 19   4   0   2 | 01445 |     T_RESU |           |  A . I . . . . . . .  |
 | 19   4   0   3 | 01446 |     T_RESU |           |  A . I . . . . . . .  |
I expected numbers in dir nb but we can see things like E0010001? What do they mean?
This is specific equipment - in virtual shelf/ board. Fot some internal purpose (like X25).
You can try to find - what is this - translator/ numbering plan.
Return to “IP / VoIP”
