Meaning of typ term
IP and Voice over IP
krutarthap
Meaning of typ term
Post by krutarthap »
Does anyone know what POS_NUM and IPT xxxx and xxxx(IP_MR types mean when we do a listerm command.
I know that
AUTPOS is analog set and
T_RESU is a port not associated (free)
Thank You.
Re: Meaning of typ term
The same answer - show output with listerm command. But for POS_NUM - you cannot understand board type and declared set type (from listerm command)?! At least you have directory number for declared set, with termstat or via mgr - you can check.
krutarthap
Release:
DELIVERY f5.401
Patch identification: 7
Dynamic patch identification: none
Country: uk
Cpu: c80s1
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
System voice guides : v4.1
(1)starter> listerm | more
Thu Apr 11 04:28:24 CEST 1996
| Coupler: 0 6 Logic type: IO1 Board: CPU_CS State: IN SERVICE |
| Coupler: 1 0 Logic type: INTMGD Board: GD State: IN SERVICE |
| Coupler: 1 1 Logic type: INTIPA Board: GA State: IN SERVICE |
| Coupler: 1 2 Logic type: CPL_MIX Board: MIX448 State: IN SERVICE |
| Cry:Cpl:ac: term| neqt | typ term | dir nb | Out of service cause |
| 1 2 0 32 | 00485 | T_RESU | | A . I . . . . . . . |
| 1 2 0 33 | 00486 | T_RESU | | A . I . . . . . . . |
| 1 2 0 34 | 00487 | T_RESU | | A . I . . . . . . . |
| 1 2 0 35 | 00488 | T_RESU | | A . I . . . . . . . |
| 1 2 0 64 | 00489 | T_RESU | | A . I . . . . . . . |
| 1 2 0 65 | 00490 | T_RESU | | A . I . . . . . . . |
| 1 2 0 66 | 00491 | T_RESU | | A . I . . . . . . . |
| 1 2 0 67 | 00492 | T_RESU | | A . I . . . . . . . |
| 1 2 0 68 | 00493 | T_RESU | | A . I . . . . . . . |
| 1 2 0 69 | 00494 | T_RESU | | A . I . . . . . . . |
| 1 2 0 70 | 00495 | T_RESU | | A . I . . . . . . . |
--More--
krutarthap
 | Coupler: 1  3 Logic type: CPL_DPT1  Board: PRA T1 State: REGISTERED NOT |
 | Coupler: 1  4 Logic type: CPL_MIX   Board: MIX484 State: IN SERVICE     |
 |  1   4   0  32 | 00533 | 4035(MR2_3 |  2100     |  A . . . . . . . . .  |
 |  1   4   0  33 | 00534 |     T_RESU |           |  A . I . . . . . . .  |
 |  1   4   0  34 | 00535 |     T_RESU |           |  A . I . . . . . . .  |
 |  1   4   0  35 | 00536 |     T_RESU |           |  A . I . . . . . . .  |
 |  1   4   0  36 | 00537 | 4035(MR2_3 |  3000     |  A . . . . . . . . .  |
 |  1   4   0  37 | 00538 |       4029 |  5000     |  . . . . . . . . . .  |
 |  1   4   0  38 | 00539 |     T_RESU |           |  A . I . . . . . . .  |
 |  1   4   0  39 | 00540 |    OP 4035 |  AA01     |  A . . . . . . . . .  |
 |  1   4   0  64 | 00541 |     T_RESU |           |  A . I . . . . . . .  |
 |  1   4   0  65 | 00542 |     T_RESU |           |  A . I . . . . . . .  |
 | Coupler: 1  6 Logic type: CPL_PRA   Board: PRA T2 State: IN SERVICE     |
 | Cry:Cpl:ac:term|  neqt | typ term   |  dir nb   | Out of service cause  |
 |  1   6   0   0 | 00545 | FANTOMICT2 |           |  . . . . . . . . . .  |
 |  1   6   0   1 | 00546 |      JONCT |           |  . . . . . . . . . .  |
 |  1   6   0   2 | 00547 |      JONCT |           |  . . . . . . . . . .  |
 | Coupler: 1  9 Logic type: CPL_GPA   Board: GPA FI State: IN SERVICE     |
 |  1   9   0   0 | 01271 |    VG_CHAN |           |  . . . . . . . . . .  |
 |  1  14   0   0 | 00533 | 4035(MR2_3 |  2100     |  A . . . . . . . . .  |
 |  1  14   0   1 | 00534 |     T_RESU |           |  A . I . . . . . . .  |
 |  1  14   0   2 | 00535 |     T_RESU |           |  A . I . . . . . . .  |
 |  1  14   0   3 | 00536 |     T_RESU |           |  A . I . . . . . . .  |
 |  1  14   0   4 | 00537 | 4035(MR2_3 |  3000     |  A . . . . . . . . .  |
 |  1  14   0   5 | 00538 |       4029 |  5000     |  . . . . . . . . . .  |
 |  1  14   0   6 | 00539 |     T_RESU |           |  A . I . . . . . . .  |
 |  1  14   0   7 | 00540 |    OP 4035 |  AA01     |  A . . . . . . . . .  |
 |  1  27   0  15 | 01302 |    VG_CHAN |           |  . . . . . . . . . .  |
 |  1  27   0  32 | 01303 |   CFN_TERM |           |  . . . . . . . . . .  |
 |  1  27   0  33 | 01304 |     AUTPOS |           |  . . . . . . . . . .  |
 |  1  27   0  34 | 01305 |     AUTPOS |           |  . . . . . . . . . .  |
 |  1  27   0  35 | 01306 |     AUTPOS |           |  . . . . . . . . . .  |
 |  1  27   0  36 | 01307 |     AUTPOS |           |  . . . . . . . . . .  |
 |  1  27   0  37 | 01308 |     AUTPOS |           |  . . . . . . . . . .  |
 | Coupler:18  0 Logic type: INTMGD    Board: GD     State: REGISTERED NOT |
 | Coupler:18  1 Logic type: CPL_EVA   Board: 4645   State: REGISTERED NOT |
 | 18   1   0   0 | 00791 |    TSYMPAC |           |  A . . . . . . . . .  |
 | 18   1   0   1 | 00792 |    TSYMPAC |           |  A . . . . . . . . .  |
 | 18   1   0   2 | 00793 |    TSYMPAC |           |  A . . . . . . . . .  |
There are so many different types of typ term that it is hard to understand what they actually mean
eg. TSYMPAC, DSP_CHAN, CFN_TERM, VG_CHAN, JONCT, FANTOMICT2, 4035(MR2_3, etc..
What do these actually maen?
Also does anyone know why the dir nb (directory number) is AA01 and how can it be a valid phone number?
You need to read sys doc and understand hardware in common. But
DSP_CHAN - DSP_channel - recourse in DSP for Q23 and so on
CFN_TERM - recource on GPA (virtual or real) for conference
VG_CHAN - recource (channel) for VG sending
JONCT - trunk (TS in E1 f.e.)
FANTOMICT2 - fantomic recource (f.e. for D-channel)
4035 - digital set type
AA01 - directory number declared for attendant set. Attendant set and group use usually dir number like this AA01, but accessible via prefix (attendant call, ..).
krutarthap
Thank You Vad for your reply. On some further investigation, it seems like all these typ 4019, 4029, 4039, 4010, 4020, 4035 (without IP) are Digital Phones
Eliott
Post by Eliott »
TSYMPAC - voice mail access
UA_VVLE, UA_VVLE, UA_VLE, UA_LE - A4001-A4012 (VVLE= Very very low end) can not remember exactly the types.
TM_DATA - Terminal Adapter V24
TYUSGS0 - S0 Port / ISDN
GAP_ENHANCED - DECT GAP+ set
UA_MR2_3G_IP - A4037
GTONN - Waiting guide on CPU port (tone 31)
and many many others...
Return to “IP / VoIP”
