GD-3 reboot issue
msdagar
GD-3 reboot issue
Post by msdagar »
hi
i am facing the GD-3 continuous reboot issue whenever we connect the OXE (rel 9.1) to the customer LAN network pls advice the solution
traces are pasted below
23/02/11 14:02:50 000001M|002/00/0/254|=2:0379=Inter ACT link HS: 23,(19,1),10.0.61.198,00:80:9f:8e:8c:9a
23/02/11 14:02:50 000001M|002/--/-/---|=2:2043=Loss of the 2 CRYSTAL
23/02/11 14:02:50 000001M|002/00/-/---|=2:2042=Loss of a GD/GD3 type cpl
23/02/11 14:02:50 000001M|002/01/-/---|=2:2042=Loss of a UA type cpl
23/02/11 14:02:50 000001M|002/02/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|002/03/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|002/04/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|002/05/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|002/07/-/---|=2:2042=Loss of a PRA type cpl
23/02/11 14:02:50 000001M|---/--/-/---|=2:2140=Alarm : TRUNK resources quantity critical
23/02/11 14:02:50 000001M|003/--/-/---|=2:2043=Loss of the 3 CRYSTAL
23/02/11 14:02:50 000001M|002/27/-/---|=3:2490=Loss of a virtual coupler GPA (2,27) of the associated coupler GD/GD3 (2,0)
23/02/11 14:02:50 000001M|003/00/-/---|=3:2490=Loss of a virtual coupler GPA (3,0) of the associated coupler MEX (3,0)
23/02/11 14:02:50 000001M|003/01/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|003/02/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|003/03/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|003/04/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:02:50 000001M|003/05/-/---|=2:2042=Loss of a Z type cpl
23/02/11 14:04:19 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.8e.8c.9a (binmg3)
23/02/11 14:04:19 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.8e.8c.9a (binmg3)
23/02/11 14:04:45 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.8e.8c.9a (binmg3)
23/02/11 14:04:45 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.8e.8c.9a (binmg3)
23/02/11 14:04:51 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.8e.8c.9a (binamcvb642x
23/02/11 14:04:51 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.8e.8c.9a (binamcvb642x
23/02/11 14:04:52 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.8e.8c.9a (bin642xconf.
23/02/11 14:04:52 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.8e.8c.9a (bin642xconf.
23/02/11 14:04:57 000001M|002/00/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
23/02/11 14:04:57 000001M|002/00/-/---|=3:5874=telnet service closed
23/02/11 14:04:57 000001M|002/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 2
Eliott
Re: GD-3 reboot issue
Post by Eliott »
How it was connected before? Spanning tree disabled?
Not easy to say why it doesn't work anymore without a Network capture.
Reason 2 means "Hardware reset on loss of DL IP" - IP Data Link lost - no IP connection between OXE and GD.
Try to make a telnet connection from OXE to GD and check, whether it's still there when connecting the customer LAN.
Make test - connect CS and GD in separated simple switch (f.e. SLANX4 on CS board).
msdagar
Post by msdagar »
thanx for support the problem got resolved after creating seperate VLan for OXE
mokhtar ACFE
Post by mokhtar ACFE »
Hi ;
which command allows me to make traces on the GD
thanks
mokhtar ACFE wrote: 19 Sep 2018 11:23 Hi ;
thanks
telnet_al
or via serial directly in that board
Return to “Media Gateway”
