When i try to call a pilot(any pilot number) i get this error: Network Link Out Of Service.
I have no ideea what happend because it worked untill yesterday.
Last thing i did was a bascul last night
Can anyone help me out?
Error "Network Link Out Of Service"
- tot3nkopf
Re: Error "Network Link Out Of Service"
Hi Mircea. Assuming you are calling a local (in the same node) pilot, probably your loopback hybrid link is out of service.
You can use
hybvisu all
command.
You should see smth like this:
List of accesses
| | Main signalling support | Stby signalling support | Nb |
| Nb | GPA State Position Support | GPA State Support | trk |
| 1 | ON UP (19, 0, 0) B Channel | | 0 |
| 2 | ON UP (19, 0, 1) B Channel | | 0 |
Note that the links are up.
Also a prefix (routing number) pointing to the same node, beginning with the first digit (or first digits) of the pilot must be present in prefix plan.
You can use
hybvisu all
command.
List of accesses
Mircea
Thanks...somenone did some settings without me knowing and it screwed up the hyb links. I deleted and recreated the links and after a restar(no bascul) it works again...crazy stuff.
Tanks again for the answer. Funny was that hybvisu showed all links up and on but none was working
