Audit Problem
vargasnunes
Audit Problem
Post by vargasnunes »
I have a OXE common hardware with version 8.0.1-g1.503 17d- with 7 others networked machines. when I try to use the
audit command I see the error below.
(108)riotkmain> audit
ooo Reading string-file /DHS3bin/oneshot/mtcl/objects.US0
ooo Reading string-file /DHS3bin/oneshot/mtcl/checkMenu.dc
ooo Reading string-file /DHS3bin/oneshot/mtcl/checkError.d
LIBC caught SIGSEGV in 2287
Registers:
EFLAGS = 0x00010206
EAX = 0x40123ca0
EDX = 0x08110010
EIP = 0x40077a50
EDI = 0x40077a50
ESI = 0x08110010
EBP = 0xbffff93c
EBX = 0x40125bbc
ECX = 0x00000058
Backtrace :
Backtrace recurence: 0 pc:0x40077a50 ebp:0xbffff93c
Backtrace recurence: 1 pc:0x400771a1 ebp:0xbffff96c
Backtrace recurence: 2 pc:0x0807b128 ebp:0xbffff9ec
Backtrace recurence: 3 pc:0x08082596 ebp:0xbffffbfc
Backtrace recurence: 4 pc:0x4002d5a0 ebp:0xbffffc38
Backtrace recurence: 5 pc:0x0807a866 ebp:0x00000000
I don't know what happens ?
Eliott
Re: Audit Problem
Post by Eliott »
Telephony not running or audit binary faulty?
sipmotor
Re: Audit Problem
Post by sipmotor »
you could try to use another language. May be the language file is corrupt. Try
audit -l GEA
there is also an option -c for character, but i don´t know the correct syntax, sorry
Return to “Inter-Node Links”
