GD-3 wont start
oliveira_Arthur
GD-3 wont start
Post by oliveira_Arthur »
Hello all,
I hava a new GD-3 but it wont be started.
After DDR RAM 256M has been load, the next step must be Flash: 2M but a lot of strange character like as diferent bit rate between VT100 and Config port is printed.
See the attach.
Arthur Oliveira
Eliott
Re: GD-3 wont start
Post by Eliott »
What was your solution?
mustafa.ahmad
Re: GD-3 wont start
Post by mustafa.ahmad »
Maybe the GD3 board was faulty or something .. y don't u try loading its binaries again using the Omni PCX installer... maybe it will help
Mustafa
oliveira_Arthur
Re: GD-3 wont start
A new one.
Arthur Oliveira
mustafa.ahmad
Re: GD-3 wont start
u can try on the same old one....
Return to “Media Gateway”
