NDDI-2 R9 stoped in Hunt group of Telecom?
bermawy
Post by bermawy »
Dear All
I have 5 lines Hunt Group from Telcom company have Voltage 66 V in NDDI-2 card is stop always so we must make Rest for time to time to can work
i want know this problem from card in my pbx or from Telecom company of high voltage ?
M.Adel
Konstantinos.E
Re: NDDI-2 R9 stoped in Hunt group of Telecom?
Post by Konstantinos.E »
when you mean stops you mean puts out of service the board?
bermawy
Post by bermawy »
when i call this hunt group(PSTN) This busy so we must make Rest to Board
bermawy
Post by bermawy »
and IN SERVICE board but have Hs of stat in trkstat command
krzysioD
Post by krzysioD »
1st thing on analog: you have good grounding / earthing installation connected to your pbx?
bermawy
Post by bermawy »
i make good Grounding have 0,5 ohm
Konstantinos.E
hi
check if you have overflow to this lines or the group...maybe stacks there.
you can check it by puting this lines out of the group and and check them one by one by calling them when you puting them again inside in the group.
so you can see witch line makes you the problem.
If this is not a problem try an other NDDI 2 board...
bermawy
Post by bermawy »
Dear
I make this steps bout this problem is still
Do you have some incidents about NDDI-2 board?
In trunks parameters you have trunk COS - External services/ trunk COS - for this COS - item "default transmission=yes"?
bermawy
Post by bermawy »
i have this default Yes so Any step another this
Return to “Shelf”
