At every reboot I have incident 2776:
2:2776=Network mgt : appearance of a node 11 not known
how can I make it disappear?
Where is node defined, to delete it?
The inter node link 11, was deleted long time ago.
My release is 3.2
Best regards
appearance of a node xx not known
- tot3nkopf
Re: appearance of a node xx not known
Maybe you still have users or trunks declared in that node?
dmpal
Indeed, I wiped from X25/Nodes of the network, nodes that no longer exists and also from Translator/Prefix Plan the users who were in those nodes.
But I still have incidents with node 0
2:2776=Network mgt : appearance of a node 0 not known
I still have a prefix
Prefix Meaning: Direct Abbreviated No.
with
Prefix Information: 0
This it might be the cause?
with
- tot3nkopf
Maybe. Is your abbreviated number declared with node 0?
Check all your configuration for objects related to node 0 (attendant, trunk groups, users, prefixes - usually routing numbers, remote processing groups, etc, etc..)
