Private to Public Overflow
zetovar
Post by zetovar »
HI All,
I´ve configured both Private to Public Overflow and Public to Private Re-routing. They are working well but i have one issue.
My numbering plan is from 216200 to 216999.
The Public to Private re-routing is working this way :
When I dial :
0(Prefix - ARS Prof.Trg Grp Seize.with Overlap) 021213509(Operator Number) 6200 (internal number) it converts in 216200 and send it trought ABC link.
This is working OK.
When the ABC link is not working and I dial 216200 it send the call by operator and complete the call to my remote node. This is OK.
The problem is if someone calls 0(Prefix - ARS Prof.Trg Grp Seize.with Overlap) 021213509(Operator Number) 6200 (internal number), the call was not complete and i get a congestion by the PBX.
Tks
ranlp
Re: Private to Public Overflow
Post by ranlp »
Try to add a second route on the force-on-net ARS table, this second route will use the public operator.
Return to “Inter-Node Links”
