Reset INTIP by Incident 5857
dmoreno
Post by dmoreno »
Hi guys,
How are you?
I´ve got a problem with an INTIP board. It´s being restarted many times and i only can see an incidente 5857 with reason 4 ( Soft reset on loss of DL backup ).
The network is property of the client and is managed by their tecnicians. I´ve asked about network statistics and they told me that everything´s OK but i think the problem is due to network failures.
Can somebody help me with this incident.
Thank you very much
dmoreno
Re: Reset INTIP by Incident 5857
Post by dmoreno »
We sent this incident to the provider and they told me to upgrade de patch version.
Now we´re working on release R8.0.1-g1.503-31-es-c0 and they recommends us to upgrade on R8.0.1-g1.503-35g-es-c0
Results coming soon...
Un saludo
sipmotor
Post by sipmotor »
the reboot of your Board is caused by a keep alive loss. Check the Keep Alive Configuration and try to increase the UDP Keep Alive & UDP Reinit counter.
Attention! You shell not set one of the counter higher than 15 (s).
Good Luck
Return to “IP”
