I´m trying to enable an ABC-IP link between two nodes, and i can see the signalling and the free TS at the suproutage menu, everything goes well until i try to make a call from N1---->N2, with the number of the extension in node 2 declared as a network number in N1.
For example:
Ext 3028 in N1, release i1.605.16.c (encrypted)
Ext 4967 in N2, release g1.503.19.a (encrypted)
The call from 4967 to 3028 works good.
but if i try to make the call in the opposite direction, the call goes to the frontdesk and after 2 seconds the call goes down automatically, i don't know why but in the MGR/IP/IP Parameters in node one there is no more the option H323 Internode Protocol, by default i think it's +False and i can't change it, so i think that there is a problem of comunication between this two nodes because also i have anoder ABC between N2 and N3 and it's working very well.
Please somebody help meeeeeee
I have attached 2 t3 files with both side calls, thanks.
Best Regards
