Error message "Access number: No more memory space (remanent)"
cwsonline
Post by cwsonline »
I am attempting to create a hybrid link with 9.0 (h1.301.45) with common hardware and a CS-2 and I get "Access number: No more memory space (remanent)" when creating the hybrid link access. I received this when I created the Inter node Link but rebooted now cannot create hybrid link access. I also see this when creating an IP Touch extension. Any ideas? Thank you.
Search the old forum. This topic has been debated before.
cwsonline
Post by cwsonline »
Debated? In any case, thank you. I didn't find a direct answer to the question in the old forums but it did get me to at least check cfgUpdate. I needed to enter values into 41-53. I am currently demoing a system and hardware.mao was not set up right. Thank you.
cwsonline wrote:... but it did get me to at least check cfgUpdate. I needed to enter values into 41-53.
So it lead you on the right track. System reboot (or double bascul in case of redundancy is needed) after using cfgUpdate.
However in these cases the best way would be to upload the good hardware.mao file (probably in your case when doing upgrade procedures only .swk file was uploaded onto the system).
Which are the symptoms of the system? (just curious)
Return to “Inter-Node Links”
