Problem with GD
zeyn
Problem with GD
Hi everyone. Sorry for my poor english
R9.0-h1.301-25-a-ru-c0
I have a problem with connecting GD2 board to CS trough WAN
CS(172.31.160.1)--->172.31.160.4)Router1(172.31.232.12)------(172.31.232.13)Router2(172.31.220.25)<----(172.31.220.26)Media Gateway
No error logs on CPU but this:
(10)xa000010> incvisu
19/11/10 16:42:51
19/11/10 16:43:07 000010I|---/--/-/---|=4:2199=A4400 Version : R9.0-h1.301-25-a-ru-c0
19/11/10 16:43:08 000010I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 0 i
nfo -1 -1 -1
19/11/10 16:43:08 000010I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1 i
nfo -1 -1 -1
19/11/10 16:43:47 000010I|---/--/-/---|=2:2176=A dynamic patch has been installed for TEL
19/11/10 16:44:06 000010I|---/--/-/---|=0:0422=IP_LINK Incident: Reference Media Gateway is not decl
ared
19/11/10 16:44:41 000010M|---/--/-/---|=5:2009=Initialisation CPU role MAIN
19/11/10 16:44:41 000010M|---/--/-/---|=5:2019=Z coupler commissioning
19/11/10 16:44:41 000010M|---/--/-/---|=5:1367=DECT network initialization
19/11/10 16:44:41 000010M|---/--/-/---|=5:5904=Remote extension network initialization
19/11/10 16:44:41 000010M|---/--/-/---|=4:0425=PRS related activity : Interface handler started
19/11/10 16:44:41 000010M|019/01/-/---|=5:2019=INTIPA coupler commissioning
19/11/10 16:48:02 000010M|000/10/-/---|=5:2169=Main CPU initialization completed
19/11/10 16:48:25 000010M|---/--/-/---|=3:1125=external alarm : "mtcl login"
GD2 writing that
/usr/bin/binmg_download: download of binmg failed: file not found on server or bad transfer or file corrupted
Here is my GD2 config
1. Startup mode Static
2. IP address 172.31.220.26
3. Netmask 255.255.255.248
4. Gateway address 172.31.220.25
5. CS role address 172.31.160.1
6. CS redundancy role address 0.0.0.0
7. Crystal number 9 (Manual allocation)
8. IP QoS menu
9. BACKUP menu
10. Duplex and speed mode menu
11. Download binaries timeout 3600
12. Passive CS address 0.0.0.0
0. Exit
and CS config
Netmask : 255.255.255.0
| Machine type | Local interface | Name | Address |
| local | Ethernet | xa000010 | 172.31.160.3 |
| local main | Ethernet | xm000010 | 172.31.160.1 |
| router | Ethernet | ndcrtu | 172.31.160.4 |
| local | IP/X25 tunnel | x000010_tun | 172.30.253.10 |
| local | Ethernet | xb000010 | 172.31.160.2 |
I have registered GDs MAC address in Shelf/Board/Ethernet parameters.
Registered tftp address in lanpbxbuild but nothing.
Maybe some idea?I don't know what to do else.
P.S. I have tried also to switch off MAC address checking by TFTPserver in IP-->INTIP B and GD parametrs
19/11/10 16:42:51
nfo -1 -1 -1
nfo -1 -1 -1
ared
GD2 writing that
8. IP QoS menu
9. BACKUP menu
0. Exit
and CS config
smileyman
- knightrider
if you can - use your laptop at the GD place and assign the IP address (from the GD to your laptop) and check you ping the CS. If ping is OK, then I think smileyman might be right and TFTP maybe blocked in the WAN/firewall somewhere.
Here at Alcatel Unleashed we open the door... but you must walk through it yourself..
zeyn
Hi, everyone!
Thanks for your response.
I can ping my CS from GD,and GD from CS frequency is 30 ms.
TFTP port is opened, i have checked it by downloading file via tftp to my laptop through WAN.
And by the way, when GD is near to CS and connected without routers, just through switch, with one subnetworks, everything works perfectly. Also i put 2 routers near cs, and simulate same situation, with same ip's. Everything ok too.
There is 18 crystals that must be connected to CS.With same configurations.So that's why number of crystal is 9.
smileyman
Hi zeyn,
yes you are right. - The problem ist not based on closed TFTP-Port. (there is an other incvisu-error)
Either it is a other needed port closed (the needed ports are in OXE-Docu (Excel-Table) o trace it via Wireshark, i mean 69, Baseport+128, UA-Signalling-Port) or it is an other problem
Do you have trusted hosts active? Is VLAN active? Is there a firewall?
The CS in any case can't see the GD and vice versa.
smileyman
smileyman
- knightrider
zeyn
Hi, every one!
Unfortunately i can not show you MG logs.(its too far)
I have noticed that i don't have /etc/xinetd.d/tftp file in this server, but i have it in another servers, i don't know why, and how it disappeared...but its fact!
After creating this file like this
service tftp
disable = no
socket_type = dgram
protocol = udp
instances = 2
wait = yes
user = nobody
server = /usr/sbin/in.tftpd
server_args = /tftpboot
Here is my new incvisu logs
24/11/10 16:11:31
24/11/10 16:11:47 000010I|---/--/-/---|=4:2199=A4400 Version : R9.0-h1.301-25-a-ru-c0
24/11/10 16:11:48 000010I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 0 info -1 -1 -1
24/11/10 16:11:48 000010I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1 info -1 -1 -1
24/11/10 16:12:27 000010I|---/--/-/---|=2:2176=A dynamic patch has been installed for TEL
24/11/10 16:12:46 000010I|---/--/-/---|=0:0422=IP_LINK Incident: Reference Media Gateway is not declared
24/11/10 16:13:21 000010M|---/--/-/---|=5:2009=Initialisation CPU role MAIN
24/11/10 16:13:21 000010M|---/--/-/---|=5:2019=Z coupler commissioning
24/11/10 16:13:21 000010M|---/--/-/---|=5:1367=DECT network initialization
24/11/10 16:13:21 000010M|---/--/-/---|=5:5904=Remote extension network initialization
24/11/10 16:13:21 000010M|---/--/-/---|=4:0425=PRS related activity : Interface handler started
24/11/10 16:13:21 000010M|019/01/-/---|=5:2019=INTIPA coupler commissioning
24/11/10 16:14:42 000010M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/11/10 16:16:43 000010M|000/10/-/---|=5:2169=Main CPU initialization completed
24/11/10 16:18:29 000010M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/11/10 16:24:55 000010M|009/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.83.bc.1c (binmg)
24/11/10 16:25:25 000010M|009/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.83.bc.1c (binmg)
24/11/10 16:25:35 000010M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/11/10 16:33:35 000010M|009/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.83.bc.1c (binmg)
24/11/10 16:34:05 000010M|009/00/-/---|=4:0740x002=Beginning of an INT/IP downloading @:00.80.9f.83.bc.1c (binmg)
24/11/10 16:34:35 000010M|009/00/-/---|=4:0740x002=Beginning of an INT/IP downloading @:00.80.9f.83.bc.1c (binmg)
24/11/10 16:35:10 000010M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/11/10 16:43:07 000010M|---/--/-/---|=3:1125=external alarm : "mtcl login"
and tcpdump logs
[root@xa000010 mtcl]# tcpdump -s 1500 -vvv port 69
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 1500 bytes
16:38:48.884742 IP (tos 0x0, ttl 62, id 0, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1024 > xa000010.tftp: [udp sum ok] 100 RRQ "lanpbx.cfg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:38:58.878333 IP (tos 0x0, ttl 62, id 1, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1024 > xa000010.tftp: [udp sum ok] 100 RRQ "lanpbx.cfg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:39:08.877935 IP (tos 0x0, ttl 62, id 2, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1024 > xa000010.tftp: [udp sum ok] 100 RRQ "lanpbx.cfg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:39:18.877670 IP (tos 0x0, ttl 62, id 3, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1024 > xa000010.tftp: [udp sum ok] 100 RRQ "lanpbx.cfg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:39:28.877405 IP (tos 0x0, ttl 62, id 4, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1024 > xa000010.tftp: [udp sum ok] 100 RRQ "lanpbx.cfg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:39:38.877262 IP (tos 0x0, ttl 62, id 5, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1024 > xa000010.tftp: [udp sum ok] 100 RRQ "lanpbx.cfg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:40:16.917381 IP (tos 0x0, ttl 62, id 7, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 100 RRQ "starttscip" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:40:26.910482 IP (tos 0x0, ttl 62, id 8, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 100 RRQ "starttscip" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:40:36.910338 IP (tos 0x0, ttl 62, id 9, offset 0, flags [none], proto: UDP (17), length: 128) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 100 RRQ "starttscip" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:40:50.234742 IP (tos 0x0, ttl 62, id 10, offset 0, flags [none], proto: UDP (17), length: 139) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 111 RRQ "startnoe-00809F83BC1C" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:41:00.230853 IP (tos 0x0, ttl 62, id 11, offset 0, flags [none], proto: UDP (17), length: 139) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 111 RRQ "startnoe-00809F83BC1C" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:41:10.230587 IP (tos 0x0, ttl 62, id 12, offset 0, flags [none], proto: UDP (17), length: 139) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 111 RRQ "startnoe-00809F83BC1C" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:41:23.450986 IP (tos 0x0, ttl 62, id 13, offset 0, flags [none], proto: UDP (17), length: 140) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 112 RRQ "startnoes-00809F83BC1C" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:41:33.450087 IP (tos 0x0, ttl 62, id 14, offset 0, flags [none], proto: UDP (17), length: 140) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 112 RRQ "startnoes-00809F83BC1C" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:41:38.450331 IP (tos 0x0, ttl 62, id 15, offset 0, flags [none], proto: UDP (17), length: 140) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 112 RRQ "startnoes-00809F83BC1C" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8
16:41:51.855479 IP (tos 0x0, ttl 62, id 16, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:41:55.853112 IP (tos 0x0, ttl 62, id 17, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:41:59.853019 IP (tos 0x0, ttl 62, id 18, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:03.852906 IP (tos 0x0, ttl 62, id 19, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:07.852801 IP (tos 0x0, ttl 62, id 20, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:20.174857 IP (tos 0x0, ttl 62, id 21, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:24.172367 IP (tos 0x0, ttl 62, id 22, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:28.172387 IP (tos 0x0, ttl 62, id 23, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:32.172405 IP (tos 0x0, ttl 62, id 24, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
16:42:36.172300 IP (tos 0x0, ttl 62, id 25, offset 0, flags [none], proto: UDP (17), length: 167) 172.31.220.26.1025 > xa000010.tftp: [udp sum ok] 139 RRQ "/DHS3bin/downbin/emg/binmg" octet ethernetaddress 00809F83BC1C crystalnumber 9 couplernumber 0 subnetmask fffffff8 blksize 1024 timeout 2
but it is still not working:(
service tftp
disable = no
socket_type = dgram
protocol = udp
instances = 2
wait = yes
user = nobody
24/11/10 16:11:31
and tcpdump logs
- knightrider
