Trunk line - lockout status
letacla21/2
Post by letacla21/2 »
Hi all,
Any one tell me how could i identify the issues,why the trunk line gets into a lockout state, below are the alarms:
16/11/10 13:22:45 000001M|000/14/0/002|=4:0279=Shift into line lockout status
16/11/10 13:12:18 000001M|000/08/0/011|=4:0279=Shift into line lockout status
16/11/10 10:52:15 000001M|000/16/0/014|=4:0279=Shift into line lockout status
16/11/10 10:52:11 000001M|000/01/0/017|=4:0279=Shift into line lockout status
16/11/10 09:33:19 000001M|000/14/0/002|=4:0279=Shift into line lockout status
16/11/10 09:21:37 000001M|000/08/0/009|=4:0279=Shift into line lockout status
16/11/10 01:19:02 000001M|000/01/0/005|=4:0279=Shift into line lockout status
15/11/10 23:23:30 000001M|000/08/0/003|=4:0279=Shift into line lockout status
15/11/10 22:02:52 000001M|000/01/0/009|=4:0279=Shift into line lockout status
15/11/10 19:07:18 000001M|000/01/0/004|=4:0279=Shift into line lockout status
15/11/10 18:36:40 000001M|000/08/0/003|=4:0279=Shift into line lockout status
15/11/10 18:10:13 000001M|000/01/0/022|=4:0279=Shift into line lockout status
15/11/10 17:17:40 000001M|000/01/0/004|=4:0279=Shift into line lockout status
15/11/10 11:58:36 000001M|000/01/0/007|=4:0279=Shift into line lockout status
15/11/10 10:03:09 000001M|000/08/0/009|=4:0279=Shift into line lockout status
15/11/10 06:48:34 000001M|000/10/0/018|=4:0279=Shift into line lockout status
15/11/10 06:18:47 000001M|000/01/0/000|=4:0279=Shift into line lockout status
15/11/10 00:17:21 000001M|000/14/0/017|=4:0279=Shift into line lockout status
14/11/10 19:19:51 000001M|000/01/0/018|=4:0279=Shift into line lockout status
14/11/10 18:35:40 000001M|000/03/0/006|=4:0279=Shift into line lockout status
14/11/10 17:58:26 000001M|000/03/0/006|=4:0279=Shift into line lockout status
But the trunk cards is in Slot 2,11 & 1 trunk grp is configured and the system info :
CPU type : cpu7
Linux version : 62.3
Delivery software version : h1.301 ;
Patch version : 28 ;
Dynamic patch version : b ;
MAO software version : H1.301.28 ;
Software Version Name : R9.0 ;
config :
| 0 | 0 | UA32|---------- | IN SERVICE | 3BA53050ABBC01 |
| 0 | 1 | Z24_2|---------- | IN SERVICE | 3BA53065NACF03 |
| 0 | 2 | NDDI|---------- | IN SERVICE | 3BA53095AWBB02 |
| 0 | 3 | Z24_2|---------- | IN SERVICE | 3BA53065NACF03 |
| 0 | 5 | eZ32|---------- | IN SERVICE | 3BA23265ABCB04 |
| 0 | 6 | CPU7_STEP2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 7 | IO2N|---------- | IN SERVICE | 3BA23190ABKD02 |
| 0 | 8 | Z24_2|---------- | IN SERVICE | 3BA53065NACF03 |
| 0 | 10 | Z24_2|---------- | IN SERVICE | 3BA53065NACF03 |
| 0 | 11 | NDDI|---------- | IN SERVICE | 3BA53095ADBB04 |
| 0 | 12 | Z24|---------- | IN SERVICE | 3BA53065AFBA02 |
| 0 | 13 | MMSFD|---------- |ONLY MAO FILE | BAD PCMS CODE |
| 0 | 14 | Z24_2|---------- | IN SERVICE | 3BA53065NACF03 |
| 0 | 15 | Z24|---------- | REG NOT INIT | BAD PCMS CODE |
| 0 | 16 | Z24|---------- | IN SERVICE | 3BA53065AFBA02 |
| 0 | 17 | GPA2|---------- | IN SERVICE | 3BA23241AAJC05 |
| 0 | 20 | CPU7_STEP2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 21 | IO2N|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 23 | Z24|---------- | IN SERVICE | 3BA53065AFBA02 |
| 0 | 24 | NPRAE|---------- | IN SERVICE | 3BA23254ABJE02 |
| 0 | 25 | Z24_2|---------- | REG NOT INIT | BAD PCMS CODE |
| 0 | 26 | UA16|---------- | REG NOT INIT | BAD PCMS CODE |
| 0 | 27 | Z12|---------- | IN SERVICE | 3BA53071AFBA02 |
thanks
Why you say about trunk line? 0-3-6 - Z24_2 board (internal analog set).
May be person dial prefix - set feature/ lock?
letacla21/2
I have given the alarms that generated from the system, only the trunk lines gets lock. no alarm related to a trunk cards.
thanks
enio.eltz
Post by enio.eltz »
Hi letacla
The problem is with analog sets, see the incinfo:
Incident number (q to quit):0279
INCIDENT NUMBER: 279
OBJECT CLASS: Dhs3Terminal
EVENT TYPE: ProcessingErrorAlarm (10)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Warning
"Shift into line lockout status"
"Analog station shift into line lockout status"
"Analog station in line lockout status. When the set returns to"
"the normal status, no other additional messages are edited."
"No system reaction"
"No operator action required";
All the boards in your alarms are Z boards. It seems like the phone offhook too much time.
Vad, do you agree with this explanation?
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
All alarms from Z equipment (0-1, 0-3, 0-8...) - Z24 boards.
F.e.
14/11/10 17:58:26 000001M|000/03/0/006|=4:0279=Shift into line lockout status (equipment 0-3-6)
from config we can see
Noting about TRUNKS.
letacla21/2
So how could i get Trunk lines alarms...or is that because of too much off-hook from the relevant equipments the trunk gets lockout.
appreciate if any tell me how could i trace the line lockout issues...
thanks
You say "trunks, trunks" - show (or explain) something about trunks.
Line in OS state, not disconnected transit calls, something else.
We see incidens with Z equipment. Nothing about TG or NDDI boards.
enio.eltz
Post by enio.eltz »
What are the problems you are having at the trunks?
You have shown us incidents with the Z boards. These are for analog phones.
As Vad said before, nothing about TG or trunk boards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
enio.eltz
Post by enio.eltz »
Or better
Explain here the problem you are having...
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
letacla21/2
my problem is trunks getting lock, (at this time all the trunks shows busy, and cannot size any trunk), so i need to trace why trunks getting hang.
Return to “External Services”
