How to reset cplalrm error counters.
Locked
stefanc
Post by stefanc »
Hi !
I have forgotten how to reset the cplalrm shown counters. Anyone outhere that has
a better memory than I have.
/S
Turlupin
Post by Turlupin »
Hi stefanc,
the command is : increset and then you make the choice 4 ... It will reset the counters of all the card
Turlupin
stefanc
Post by stefanc »
YES , that was it, now I remember, thanks for your help
Your are gold :-)
/S
Locked
Return to “Shelf”
