Remote Desktop thru ABC-F tunnel
letacla.alcatel
Is ther any way to route the Ehernet connectivity B/W 2 nodes, thru ABC-F Tunnel.
I have two nodes connected by ABC-F TG, I have PC for maintenance for bothe end.I would like ping the PC both side, for Remote Desktop.
To have voicemail maintenance from another end..
Pls......
Thanx
Alcatel fan
Pls......
Thanx
Alcatel fan
Why not possible? F.e. node 1 and 2 (netw 0), tunnel addresses - 172.30.253.1 and 2. F.e. PC1 10.253.1.10 (mask 255.255.255.0), PCX1 10.253.1.1.
PC2 10.253.2.10, PCX2 10.253.2.1
If you want to manage PBX2 from PC1.
Manage GW (PC1) 10.253.1.1 - use PCX1 like gateway.
Manage PCX2 (netadmin -m) - static route for host 10.253.1.10 (PC1) use GW 172.30.253.1 (tunnel from PCX1).
Now you can ping 172.30.253.2 (PCX2) from PC1.
If you want to ping PC2 from PC1 - manage PCX1 (netadmin -m) - static route - host 10.253.2.10 (PC2) via GW (172.30.253.2 - tunnel PCX2).
And GW for PC2 - 10.253.2.1
swinstation
dear vad
is it possible to explain the 3rd post with more details again?please -I have 2 site and they have own pc and ABCF and tunel working fine,now can you tell me again about connecting computers together?
node1:172.30.253.1 real IP:217.219.43.1 pc:217.219.43.10
node2:172.30.253.2 real IP:192.168.1.10 pc:192.168.1.30
swinstation
dear vad
is it possible to explain the 3rd post with more details again?please -I have 2 site and they have own pc and ABCF and tunel working fine,now can you tell me again about connecting computers together? for example:
letacla.alcatel
Dear All,
Its ABC-F link only, not through the ABC-F trunk..!!!
I have succeeded for this issue, but it’s very slowing also manageable..!!! Thanks to VAD...!!
Follow the steps...
IP details:
Node 1 - OXE: 10.253.1.3, Tunnel: 172.30.253.1, PC1: 10.253.1.10
Node 2 – OXE: 10.253.2.3, Tunnel: 172.30.253.3, PC2: 10.253.2.10
On OXE Node 1: PCX static route managed as a host 10.253.2.3(which is node2 Role Address) GW: 172.30.253.1
On OXE Node 2: PCX static route managed as a host 10.253.1.3(which is node1 Role Address) GW: 172.30.253.2
On PC1: route ADD 10.253.2.3 10.253.1.3 (Node 2 OXE IP, GW: Node 1 OXE IP)
On PC2: route ADD 10.253.1.3 10.253.2.3 (Node 2 OXE IP, GW: Node 1 OXE IP)
After these configurations we can able reach (telnet) from the PC1 to Node2 and PC2 to Node 1
If PC1 to PC2 ping (Remote Session)
On PC1: route ADD 10.253.2.10 10.253.1.3
On PC2: route ADD 10.253.1.10 10.253.2.3
Thanx
Alcatel fan
Follow the steps...
IP details:
Thanx
Alcatel fan
