CPU 6 and CPU7-2 Compatibility
waqasrehman06
Post by waqasrehman06 »
Plz i need some help regarding Compatibility between CPU-6 and CPU-7-2.Is it possible to manage duplication between these two different CPU with same release?
Thanks in advanced
Waqas
I don't think this is officially supported. I don't think Actis will let you configure duplication with 2 different types of CPU's.
However this is working. Some time ago I performed an upgrade from R6 to R8 or 9 (I don't remember), having duplicate CPU's, with CPU replacement. I did that without bringing the PBX down -->the duplication worked when replacing one old CPU with a new one.
waqasrehman06
Thanks for the reply Bro
I will test and let you know its working or not
Thanks once again:-)
Return to “Shelf”
