Upgrade 6580
sacaminas
Upgrade 6580
Post by sacaminas »
Hello sir, I have a 6850 with this version:
System:
Description: 6.3.4.378.R01 GA, March 11, 2009.,
Object ID: 1.3.6.1.4.1.6486.800.1.1.2.1.7.1.1,
And I had some problems and Alcatel advise me that I should upgrade it to OS6850_6.4.3.609.R0. version.
This AOS contain this files:
This will be the first time that I´m going to do it.
Some one can help me to do this?
Thanks very much
there are some ways for loading new sw into the switch (ftp, tftp, scp....).
For use of FTP you need ftp-rights:
> aaa authentication ftp local
You need a ftp-client-tool (f.e. ftp32) to connect to the switch (use your switch-admin-user). At the remote site you should see the working directory of the switch. Load the images (all files *.img) with the ftp-tool to the working directory.
Then check the loaded SW in working with:
> show microcode
If all files are the new one you can reboot the switch with:
> reload working no rollback-timeout
You can check with:
> show microcode loaded
If all is fine you need:
> copy working certified
