Remote shelf in South Africa
airwolf
Post by airwolf »
My customer is wanting a remote gateway installed in South Africa(pretoria) running off the main OXE in UK, They want to have an ISDN30.
My question is, do I set the ISDN30 up the same as I would here in the UK?
Thanks in advance
tincho.rn
Post by tincho.rn »
Yes. Regards.
airwolf
Post by airwolf »
Many thanks for that, I am right in thinking the power supply voltages are the same, I.e a uk spec shelf will work. (apart from the 3 pin uk plug)
Return to “Shelf”
