Used compressors
dryhouse
Used compressors
Post by dryhouse »
Hi brots,
i have one OXE´s network in star, the node 1 is the central node. It has hybrids links with node 2 and node 3.There is network visibility between them. In an ABC call from node 2 to node 3;¿are compressors of the node 1 used ?
Thanks.
If VPN overflow (1-2, 1-3, 2-3) and VPN prefixes present everywhere. If in IP parameters Direct RTP=true - Node 1 compressors not used during calls node 2 - node 3.
You will have direct IP calls from node 2 to Node 3 VPN prefix.
Return to “Inter-Node Links”
