How to view Prog.Keys of a User ?
kaseOga
Post by kaseOga »
What is the command to view the progamable keys of an extension (directory number) ?
Thanks !
mgr/ users/ programmed keys
kaseOga
Post by kaseOga »
In a command? Not in nvestigr, thx
Turlupin
Post by Turlupin »
Or you can use this command on the cli :
> readkey mcdu=Extension
Konstantinos.E
Post by Konstantinos.E »
nice command!!
swinstation
Post by swinstation »
yes nice command
kaseOga
Post by kaseOga »
i can see the memo on the prog keys with this command ???
From my point of view - the best solution - to use management tool (4760i) - you can see what you want (especially if you use UTF-8 name).
kaseOga
Post by kaseOga »
i use 4760 but i need commands to do an script to see "Memos", with readkeys i dont see the memos :( any command more ?
thanks for all coments !!
kaseOga
Post by kaseOga »
any one knows any command to see the memos of prog keys of a mcdu¿¿
Return to “Linux tricks”
