So i bought two SFP-DUAL-MM but i do not get it to work:
Put into combo port 2 & for for connecting a cisco2960 (Port 1/2 1000full) and the Media Converter Port 4 (100full)
-> show ni
Module in slot 1
Model Name: OS6850-P48L,
Description: 48 10/100 POE,
Part Number: 902546-90,
Hardware Revision: 02,
Serial Number: XXXXXX,
Manufacture Date: APR 05 2007,
Firmware Version: ,
Admin Status: POWER ON,
Operational Status: UP,
Power Consumption: 95,
Power Control Checksum: 0x96a0,
CPU Model Type : Motorola MPC8248,
MAC Address: 00:e0:b1:6e:7a:6c,
ASIC - Physical 1: BCM56502_B2,
ASIC - Physical 2: BCM56504_B2,
FPGA - Physical 1: 0019/00,
UBOOT Version : 6.1.3.601.R01,
UBOOT-miniboot Version : 6.1.3.601.R01,
POE SW Version : n/a
GBIC 2
Manufacturer Name: FIBERXON INC. ,
Part Number: FTM-3413C-SL05G ,
Hardware Revision: 10 ,
Serial Number: XXXX ,
Manufacture Date: XXXX ,
Laser Wave Length: 1310nm,
GBIC 4
Serial Number: YYYY ,
Manufacture Date: YYYY ,
-> show system
System:
Description: Alcatel-Lucent OS6850-P48L 6.4.3.520.R01 GA, April 08, 2010.,
Object ID: 1.3.6.1.4.1.6486.800.1.1.2.1.7.1.16,
Up Time: 8 days 6 hours 23 minutes and 23 seconds,
Contact: Alcatel-Lucent, http://alcatel-lucent.com/wps/portal/enterprise,
Services: 72,
Date & Time: TUE SEP 07 2010 16:25:58 (CET)
Flash Space:
Primary CMM:
Available (bytes): 7994368,
Comments : None
interfaces 1/2 hybrid FORCED-FIBER
interfaces 1/4 hybrid fiber speed 100
I get no link neither to the cisco nor to the media converter, switched RX/TX of the cable, no luck.
Any hints?
