oxe cpu connections
rav_sk
oxe cpu connections
Post by rav_sk »
dear all,
Please tell me how to connect cpu with Cbrma .Model is Oxe ,CPU 7-2,Release 9.0.
Ravinder
Engineer
enio.eltz
Post by enio.eltz »
Hi Ravinder
You need to use CBRMA cable. It comes with OXE, reference 3BA28022AB or 3BA28022UB. You connect this cable at the back panel ( CPU slot ) and at the CBRMA box. You will have all the connections there. LAN, serial ports, etc.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
sera544
Post by sera544 »
Hi ravinder,
May i add something, this connections are well described in the system document, go to installation manual, internal or external connection, u can see with diagram, sometime part number change but still u can figure out from this diagrams...still u didnt understand get back to us,
cheers,
Pandian
Return to “System”
