whatis the satured
buraka
whatis the satured
Post by buraka »
Hi, I have two node I m looking to suproutage menu sometimes 1 and 2 node satureted
I can check the intip board compress chanell all line free and carrier(service provider) 5MB data free but voip call not working
why or how this link satured I can rsthyb all command and vpn reset but not working
I can reboot to system after the link okey :(
I can't understand how I Solve this problem
if you see attech files
thank a lot
hybridlink.txt
Chamizo
Post by Chamizo »
Please show the incidents using command incvisu.....
Chamizo
buraka
voip problem
Post by buraka »
I will attech the incdent number don't worry :)
thank you
Return to “Inter-Node Links”
