RESTRICT a user to call another node on ABCF
Locked
swinstation
Post by swinstation »
Hi all
is there a way to forbid a user on node 1 to calls another users on node 2?
and it can dial just node 1's extension.
Use a connection category without access to the category of ABC trunk group?
krzysioD
Post by krzysioD »
Good, but only if:
2 nodes in network
you don't use trunks from another node (if your company has GSM gateway or sip-gateway connected to another node)
maybe connection category user to user?
swinstation
they are connected with using inter node link and connection cos or trunk group access are not good idea.
but there is network access cos on class of services what is that?you know?
swinstation
I solvee,you can restrict a user with network access cos in Class of service
Locked
Return to “Inter-Node Links”
