ACT media gateway INTIPB
Rezakaa
Post by Rezakaa »
In an ACT Media Gateway with INTIPB what is the ethernet configuration?? (auto nego. half and full duplex, forced 100MB full duplex, etc). This parameter apear in a configuration of an INTIPA but not in an INTIPB. Does anybody knows?.Apparently this is causing a reset of the ACT media gateway, this is the incident that shows:
22/07/10 15:00:01 000000M|001/20/0/254|=2:0379=Inter ACT link HS: 23,(19,1),172.16.16.8,00:80:9f:8c:ee:e6
Or what can be happend, i hope you can help me.
Regards.
murraya
Post by murraya »
you should be able to configure the sppee detc by the console port on the INTIPB Rezakaa.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Rezakaa
Post by Rezakaa »
I will try and let you know. thanks Murray
Rezakaa
Post by Rezakaa »
Murraya you were right I could change the speed of the ethernet conection through the console port, but the problem persists ACT is reset from time to time, the error is as follows "22/07/10 15:00:01 000000M|001/20/0/254|=2:0379=Inter ACT link HS: 23,(19,1),172.16.16.8,00:80:9f:8c:ee:e6", with incinfo shows:
INCIDENT NUMBER: 379
OBJECT CLASS: Dhs3Terminal
EVENT TYPE: EquipmentAlarm (4)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Major
"Inter ACT link HS: P1"
"P1 : Error type"
"P2 : IP Inter-crystal Link out of service"
"P3 : Internet address of INTIP_B"
"P4 : MAC Address of the INTIPB if possible"
"Inter-crystal signaling link problems on"
"link establishment or existant link shutdown"
"Several causes"
"Depend of the error value:"
" 0 Link out of service - IP Coupleur IP not initialized"
" 1 Link out of service - MAC Address already allowed"
" 23 Link out of service - No more signalling ressources"
" (There is no INTIPA in service)."
" 24 Link out of service - following INTIPA deletion"
"no reaction of the system."
"Check IP ressources boards within intipb."
"To see timer used tabtemp tool.";
I think it has something to do with the connection inter-ACT but not sure what to do, any ideas?
I hope you can help
leo
Post by leo »
Hope the shelf address is correctly managed on INTIP board via DIP switch settings.
Rezakaa
Post by Rezakaa »
yes it is leo, if would not be that way the ACT dont work, anyway i will check again. thanks if you have any idea let me know
btlasisi
Post by btlasisi »
You may be having Speed/Duplex mismatch between your INTIPB 10baseT ethernet board and your switch port.
Rezakaa
Post by Rezakaa »
btlasisi i already configure the speed of the ethernet board and thats not the problem, other idea? thanks
leo
Post by leo »
Is there any INTOF connection with 4*64 kbps signaling being used ay ur site?
Rezakaa
Post by Rezakaa »
No there is not, but there is a INTIPA connected i dont know if this is relevant for the case.
Return to “Media Gateway”
