The redial list?
I can't think of a way to turn it off.
The missed calls?
If you have a Alcatel OmniPCX Enterprise and access to the configuration, you can turn that feature off by setting the feature "ISDN Subscr." "External" and "Internal" to "False" at the user configuration.
There is a list of 10 call witch were outgoing...
If it is a public phone, all user can see witch numbers are roung..
If it is a hotell room, new quest can see the call log...
I don't want to use this list...
I think it probably is a tel facil issue..
I have allredy removed internal/external isdn subscriber...
Under the USER , ISDN section. You have something about EXTERNAL CALLERS and INTERNAL CALLERS, by default it s set to TRUE. If you turn if off, you won t have any call log on that.
