CS-2 card bootup problem in the L cabinet
Kannan.nagaian
Post by Kannan.nagaian »
I have CS-2 in redundancy configuration in the common hardware. One CS-2 in S cabinet and it is working fine and the second card in L cabinet which does not give bootup sequence (not working) in the hyper terminal.
It is a new installation and if I insert the card in S cabinet then it is working fine. Is there any micro switch setting in the CS-2 card or anything i missed for for the CS-2 card installation in the L cabinet.
Any help would be appreciated.
Kannan
Mr T
Post by Mr T »
What slot are you installing the board in the L cabinet?
Kannan.nagaian
In Controller slot GD board and CS-2 in slot 8
oldboy
Post by oldboy »
What are you actually getting when the CS is trying to Boot up in the large shelf? You have turned the power on the GD board havent you? (Sorry just have to ask?):confused::confused:
Mr T
Post by Mr T »
If you aren't getting any output on the CS when powered on, than it's the slot on the shelf that's bad.
Kannan.nagaian
Hi Mr T,
The L cabinet is working fine with other cards. when I switched ON the CPU the CPU LEDs are blinking then it goes to OFF condition in the L cabinet.
If I insert the CPU in S cabinet it is working fine.
murraya
Post by murraya »
Hi, check switch 4 is off on the CS in slot 8. It shoul only be on if the CS is in the controller slot to monitor power/batteries.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Kannan.nagaian
Hi Murray,
Thanks for your reply.
This is CS-2 card. Will it also have the switch setting?
murraya
Post by murraya »
Should do.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Kannan.nagaian
I checked the micro switch setting and found that the switch 4 is OFF only in the CS-2 card.
Return to “Media Gateway”
