Echo coming from remote shelf
mustafa.ahmad
Post by mustafa.ahmad »
The scenario is that we have one remote shelf connected thru INTIP card, which is using modem to connect to main shelf.
Now whenever anyone from remote calls, there is echo during conversation.
OXE_4400
Post by OXE_4400 »
echo elimination deep depends on OXE release, don't remember exactly, but it was increased from some 32ms till 128ms. You need to check Your OXE release,patch with docs.
mustafa.ahmad
Hi OXE-4400,
it is R8. 0 ,G150138 .
Is there any parameter where we can modify to get the desired echo elimination...
OXE_4400
Post by OXE_4400 »
It depends on subcard.
TC1018-ed03:
The echo delay can no more be managed. It is set automatically according to the hardware used:
• GIP6-GIP6A-MCV8-MCV24 board: the echo delay is limited to 32 ms.
• GIP4-1/GIP4-4/MADA-1/MADA-3 board: the echo delay is limited to 128 ms.
alex
Post by alex »
Run "compvisu sys" command to check and you'll get something like this
| C O M P V I S U |
| Inter-node protocol H323....... yes |
| RTP Direct..................... yes |
| RTP Direct for H323 terminals.. no |
| Fast Start..................... yes |
| VAD (Voice Activity Detection): |
| - G723/G729...... yes |
| - G711........... no |
| ECE (Echo Canceller)........... yes |
| - LIO/LIOE........ 16 ms |
| - INTIP/GA/GD..... 128 ms
So who does experience an echo - everybody on remote shelves being called or persons called by extensions from the remote shelf?
mustafa.ahmad
i am using GIP4-1 daughterboard... shall i change it to GIP6... ??
the echo is coming when we dial from the remote shelf.. to the user in the remote shelf....
thnx fr the replies...
FROM the remote shelf TO the remote shelf ?
So it's local to the remote shelf ?
alex
Post by alex »
mustafa.ahmad wrote:i am using GIP4-1 daughterboard... shall i change it to GIP6... ??
See no sense right now.
Do you have different types of extensions - analog, UA, IP?
Is there echo on conversations with all of types os sbs?
mustafa.ahmad
sorry regarding my previous reply... the echo is coming when u dial from the remote shelf to outside .... the users within the remote shelf do not experience echo...
yes we have analog and UA extns bt nt IP...
there is this parameter nb of compressors... in the INTIP board COnfign.... which i think m making it wrong....
wht shud i set it to if i hav 1 GIP4 daughterboard.....
Return to “Shelf”
