Dial by name problem
RobertBreu
i got a problem in an upgraded oxe (r 5.1 linux => R9.1) with the internal phone book.
I have a name in the phone book (Plöchinger). If i search this name from an 4020 (Premium) i got the following problem:
- If I type Plö and then enter it says that i have to modify my search
- If i type Plo and then enter it gives me the right entry (Plöchinger)
I have done a test on another oxe with a new installed R9.1 and on this system it works, so it must be something with the old database.
Thanks for your help!
Robert
Robert
Mr T
smileyman
RobertBreu
smileyman
Hi Robert,there are some examples from users with the same or similar problems: http://old.alcatelunleashed.com/viewtop ... t=fallback http://old.alcatelunleashed.com/viewtop ... llbackbest Regards smileyman
smileyman
RobertBreu
i have tried everything you mentioned but got no sucess...
alexeik could you send my an e-mail with the fallback and the pbmd file? (rb@call-data.de)
Tanks
Tanks
RobertBreu
