Remote extention not working
nalinda
Post by nalinda »
I configure remote extention for mobil phone no (718411290)
1)translator-->prefix plan--> create
No : 350
P.Meanning:Remote extention disa
2) Trunk group-->trunk group-->Review modify-->
T.group ID 5
TG Used in disa YES
3)User--> create
D . No 411
S.add. 255
B. add 255
E. add 255
Set type Remote bextention
User--> remote extenton
D.No 411
R e. No 9718411290
4)Vertual user create
D.no 412
S.add. 255
B. add 255
E. add 255
Set type Analog
Ghost True
Ghost feature R.Extention
Application --> R.Extention parameter
Defoult value
But this configuration not working
PLs .help us
Nalinda
Not working - explain please. Remote extention user cannot be called from internal (PBX) set? Or you have problem with incoming call - in your management absent speed dial (for automatic substitution). Something like this - Prefix=A1000 (f.e.), Call number=0718411290 (if you use 0 like outgoing seizure prefix - in ext. callback translation too), Ext. DISA number=411. And in system/ other system/ DISA param - automatic substitution must be allowed.
nalinda
Remot extention not working
Post by nalinda »
Internal calls working fine.But my mobil no 718411290 cant accses any digit for in comming and out going calls
thanks
Note.
Nalinda kumara
freedom
Post by freedom »
Did you assign your mobile number as a speeddial number with a relation to the remote extension number for automatic recognition?
Do you hear the voiceguides if you call to the DID number 350 from your mobile?
Return to “Users”
