Noise heard on handset OXE
fajar
Post by fajar »
Hi, I have problem on some handset analog and digital, sometimes it is heard voice of another person next to the room, is there any way to avoid this matter?
Konstantinos.E
Post by Konstantinos.E »
hello
1.make a reset of the boards in the users that u have this problem with the command rstcpl.problem solved?
2.make reset th hole system.problem solved?
3.put out the boards of the self to ensure that is a hardware problem.
4.do u have any incident?
cheers!
fajar
Post by fajar »
Have tried no 1 and 2, for number 3 do you meant to exchange the board with another?,
for the incvisu which statement indicates the problem ?,
Hi Fajar,
He probably meant to change the board.
Do you hear the other person even when you MUTE you phone ?
fajar
Post by fajar »
When it's not in call condition, no other voice heard except tone, if it's you mean by mute condition, or is there any other mute condition?,
mustafa.ahmad
Post by mustafa.ahmad »
maybe u can check if there are two digital phones running on the same cat3 or cat5 cable... at times there is cross-talk or interference if we operate 2 digital phones on the same cable.....
hope it works
fajar
Post by fajar »
Yes guess it is about crosstalk, any suggestion?, since we can't do the recabling,.......
leo
Post by leo »
Create test scenarios. Connect the users having issues directly at the MDF...this will atleast pin point the root cause...cabling or something else.
mustafa.ahmad
if there are two extensions running on the same cable, then make one of the extns out f serv. by givin shelf, board, eqpmnt addrss as 255.
then establish call to other extn, if the problem is resolved, then u will hv to shift one f the digital extn to another cable.
fajar
Post by fajar »
If doing test on the MDF closest to the Card (Z or UA) no noise heard, the noise only heard on the user, after hops 2 MDF and 1 patch panel , we use multipair cable to connect between the MDF on each floor, on one cable run 50 or 100 pairs line, Is it normal for the line connection ?
Return to “Shelf”
