Question about RAR files
If you wrote a good one, share it with us !
mboyra
Problems accesing the documentation
Post by mboyra »
I've downloaded the v7.1 RAR file, I've decompressed it, I've executed the application, but the an "500 HTTP Error" is shown.
I've also tried creating an IO and mounting it on a virtual device unit. I've installed several versions of the Apache for Windows XP, but nothing seems to work.
What do I have to do to be able to see the documentation files?
Thanks in advance
Did you check that you do not have another HTTP server running ?
Also, use Internet Explorer, and try http://localhost
If you see a list of folders, click on ALCATEL
If you don t see that, then it's something on your computer.. (firewall ? http configuration ? )
mboyra
Post by mboyra »
Hi Frank,
Thank you so much for your help. It was a problem with the web browser configuration. I've had to disable the proxy to be able to access the content of the documentation.
Thanks!
Return to “Documentation”
