I hope you are doing well
I Have OXO system
when i make external call and the required side are busy
i recall agin by using redial button
but that impossible
so only reply calls i can to make redial on it
please tell me how i can make redial for any calls(reply or not reply)
thank & regards
Redial Last Number
etc
Suppose, you have analog trunk lines. The dialling number would be stored in redial list (on analog lines): 1) - after switching to conversation (by timer); or 2) by reaching the format in Numbering/ End of Dialling table. Timer you can change in External Lines/ Protocols/ Analog trunks/ Modify/ Off-hook Simul. ... numbers.
End of dialling table is only one for whole PBX. You can have problems for fiilling in this table, if you have different format on same digits in different directions.
sameh
