Backplane cabling layout for VPU5
tjm0852
Post by tjm0852 »
Anyone have any documentation regarding how the cabling should be connected on the backplane of a VPU5 in a M2 cabinet? Or can you tell me on what pins what should be connected to?
Need to know where the connectors from the BRMA and Ehternet go.
Thanks in advance
tjm0852
Post by tjm0852 »
The V24 cable goes on the top most connector on the back plane. Leave 9 pins exposed and connect the first row of the Ethernet cable to the 10th pin down from where the V24 is connected. Refer to the bottom right hand corner of the image I have attached.
SPYRO68
Re: Backplane cabling layout for VPU5
Post by SPYRO68 »
Hi do you still have the picture, the attached one doesn't exist anymore.
Thanks in advance
Return to “Voicemail (46x5)”
