R 9.1 CS-2 & GD-2 wont load with PC Installer 2.24???
MTConsulting
Post by MTConsulting »
Guys,
i am stuck on a site Looong way from home with a new system, I think it has been made up of parts, CS-2 is a 'crash replacement' GD-2 is also blank!!
I am using PC installer 2.24 to try and load 9.1 on the CS-2 and cant get past the bios menu as follows:
Version 1.23.1109. Copyright (C) 2007 American Megatrends, Inc.
ALCATEL CS-2 BIOS VERSION 0ABPT090
CHECKING FOR BATTERY MODE:
BATTERY MODE NOT DETECTED. BOOTING SYSTEM.
Press ^B to enter setup.
Press ^I to boot EFI SHELL
(dont type anything I get)
Intel(R) Boot Agent GE v1.2.16P7
Copyright (C) 1997-2003, Intel Corporation
Initializing and establishing link...
(it looks for a mac for DHCP)...then restarts!
(If I hit Ctrl-S)
Setup Menu
<Esc> <Space> <
* Network Boot Protocol PXE (Preboot eXecution Environment) *
* Boot Order Use BIOS Setup Boot Order *
* Show Setup Prompt Enabled *
* Setup Menu Wait Time 5 seconds *
Select remote boot protocol.
<Esc> <Space> <Enter> <F4>
Cancel Changes Change Value Next Option Save Configuration
(If I hit Ctrl-B I get)
Aptio Setup Utility - Copyright (C) 2007 American Megatrends, Inc.
Main Advanced Chipset Boot Security Save & Exit
ZDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDBDDDDDDDDDDDDDDDDDDDDDDDDD?
3 BIOS Information 3Choose the system 3
3 BIOS Vendor American Megatrends 3default language 3
3 Core Version 4.6.3.1 3 3
3 Project Version 0ABPT090 3 3
3 Build Date 5/8/2009 14:22:10 3 3
3 3 3
3 Memory Information 3 3
3 Total Memory 1024 MB (DDR2) 3 3
3 3 3
3 Package SKU EP 80579EZ600C 3 3
3 3><: Select Screen 3
3 System Language [English] 3: Select Item 3 3
3 3Enter: Select 3
3 System Date [Tue 05/31/2005] 3+/-: Change Opt. 3
3 System Time [03:07:36] 3F1: General Help 3
3 3F2: Previous Values 3
3 Access Level Administrator 3F3: Optimized Defaults 3
3 3F4: Save ESC: Exit 3
3 3 3
@DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDADDDDDDDDDDDDDDDDDDDDDDDDDY
(I cant get into boot from etherent menu??, card is in slot 0, have tried various DIL setings?...On is toward the HDD , Off towards the MASSIVE heat sink. I am 1 = ON 2,3,4 = OFF. Is this correct to force a load from ETH?)
Any help greatly appreciated.
MTConsulting
I have PC Installer set to Alize & CS-2 and it makes no difference!!!! Am also using crossover cable direct to laptop and static address of 192.168.45.69 CS-2 is .70.
JoelO
Post by JoelO »
You should type ^B and immediately followed by ^I to get the boot menu on the CS HD.
JoelO
Post by JoelO »
Then select boot from Ethernet. You should be choosing Alize and the country, along with direct cable if you are plugged into the PBX.
MTConsulting
Hey Joel,
I Type Ctrl B and before i get to type Ctrl I it goes this way:
3 3 3
3 3 3
3 3Enter: Select 3
3 System Time [04:26:11] 3F1: General Help 3
3 3 3
MTConsulting
Co
CLIENT MAC ADDR: 00 80 9F 8D 22 52 GUID: 00020003 0004 0005 0006 000700080009
PXE-E51: No DHCP or proxyDHCP offers were received.
PXE-M0F: Exiting Intel Boot Agent.
(the reboots!!)
MTConsulting
have just put a HDD from a working system on this CS-2 and it boots fine??
MTConsulting
when I type Ctrl-B i get this only??
Entering Setup...
3 Password Description 3Set Setup Administrator 3
3 3Password 3
3 If ONLY the Administrator's password is set, 3 3
3 then this only limits access to Setup and is 3 3
3 only asked for when entering Setup 3 3
3 If ONLY the User's password is set, then this 3 3
3 is a power on password and must be entered to 3 3
3 boot or enter Setup. In Setup the User will 3 3
3 have Administrator rights 3 3
3 3 3
3 Administrator Password 3: Select Item 3 3
3 User Password 3Enter: Select 3
3 3+/-: Change Opt. 3
3 3F1: General Help 3
3 3F3: Optimized Defaults 3
3 3 3
JoelO
Post by JoelO »
You should see this:
Alize BIOS Monitor
*** BIOS Version 3EH30227EIAA bios100/008.033 ***
*** Generated on Nov/04/2004 at 14:51 ***
memory test started lng=133169152 with 0
running flash(soldered=1
socket=0)=1,BIOScase:4,BIOSv24:0,verrou=1,algoNOR=1,size=1,base=3ff80000
DIMM characteristics->: JEDEC Manu ID:h,
Memory type(EDO,FPM..):0x04
# of row address:12
# of col address 10
# of module row 1
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI:scan_bus for bus 0
PCI:bus=00h,devfn=00h ,[vendor:device]=[1022h/3000h]
PCI:bus=00h,devfn=60h ,[vendor:device]=[100bh/0020h]
PCI:bus=00h,devfn=98h ,[vendor:device]=[1064h/2101h]
PCI:scan_buses with 00h secondary buses
PCI:command =000003ffH for device 00:00
PCI: Assigning I/O space fc00-fcff for 00:60 BAR=00000010
PCI:Assign memory space bffff000H to bfffffffH for device 00:60
PCI:command =000003ffH for device 00:60
PCI:Assign memory space bfffd000H to bfffdfffH for device 00:98
PCI: Assigning I/O space fd00-fd1f for 00:98 BAR=00000014
PCI: Unable to handle I/O allocation for 00:98 (ff04) BAR=00000018
PCI:command =000003ffH for device 00:98
assigning irq10 to xchange
B0 = 17
DRCTMCTL = 1e
DRCCTL = 18
DBCTL = 11
Set external RTC
Set Internal RTC
No external RTC detected
gpbus sig timing : 0-2-1-2-1-2!
CMOS is available
Xchange PCI mem base OK: 00000000
Xchange PCI IO base OK: 00000000
Xchange irq OK: 0a
PCI command read for natsemi : 00000347
PCI Master Bit Setting...
pci_command set to:0357
0000 0080 009f 002f 00db 0058 , IRQ 12.
eth0: Transceiver status 0x00007869 advertising 000005e1
Hard Disk #0 : FUJITSU MHK2060AT 5729 Mo
Parameters :
Type 00000
Extended Type 00255
Sectors / track 00063
Landing Zone 00000
Control Byte 00000
Write Precomp 00000
Heads 00015
Nb of Cylinders 12416
HD size(cyl*sec by track*head*sector size) 06007 MO(decimal)
init nand set interupt
Flashfx version:520.001.001
Cannot mount flash drive No 0. Flash NAND may not be formatted !
NAND Flash Comfiguration:
CPU size : 32 MBytes
free spare blocks: 38
XMEM size : 0 MBytes
NAND Flash Details:
chip #0 : Type=TC58256 Id=9875H Size=32(MBytes) Unit size=16384 Page Size=512
time :sec=31,min=32,hour=15,DoW=06,date=06,Month=07,year=05
time :sec=35,min=32,hour=15,DoW=06,date=06,Month=07,year=05
ALIZE informations :
Memory Detected : 131072 Ko
Flash Detected
DaughterBoard Not Detected
XCHANGE Detected
XCHANGE Chip Initialization OK
Ethernet Found : 1
Ethernet Chip Initialization OK
Hard Disk Detected
Hard Disk Found : 1
DMA enabled
PCM11 selected
No HD trace
CPU at 133 mhz
check lock RTC
value of DIL switch 01
YOU CAN strike Ctrl B to enter in BIOS monitor during several seconds from NOW !
Caution: When this message is displayed, a timer is triggered (several seconds): Enter the sequence “Ctrl + B”
hit [Ctrl I] for BIOS monitor!
Enter the sequence “Ctrl + i”
Password?:
Type return (no password)
Watchdog disabled
Alize BIOS Monitor
Monitor Light Menu
01 - Load From Hdisk #0
02 - Load From Ethernet
03 - Load From Flash NAND program
04 - Load From Flash NAND program and Bootp
05 - Load From Hdisk #0 and Bootp
06 - Display MAC address
07 - Display PCMS id
08 - Display System informations
09 - Full Options menu
10 - Reset System
? 2
JoelO
Post by JoelO »
Is this a new HD?
Return to “Media Gateway”
