Alcatel Unleashed
The #1 Worldwide board for technical support on Alcatel-Lucent Voice & Data gear.
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Home Board index VOICE - OXE (OmniPCX Enterprise) PWT/DECT System
  • Search
GAP compatible DECT-Phones and lost connection?
  • Print view
Advanced search
10 posts • Page 1 of 1
sputniki
  • Quote
Post by sputniki » 13 Apr 2010 10:38
Did anyone expirienced this:
In one Client-OXO-Setup many DECT Mobiles seems suddenly to have sometimes to have no connection to the IBS while an Alcatel Mobile Reflexes 200 does. Three years all went fine, but now they sometimes suck for a few seconds without any (known) reason.
We use Siemens/Gigaset DECT/GAP-Handsets in various installations but never had such problems with them. Maybe that all thirteen handsets have radio problems, but that's not probable...
Top
Konstantinos.E
  • Quote
Post by Konstantinos.E » 13 Apr 2010 18:37
i have never seen siemens dect working on alcatel ibs.
r u sure u connected before siemens dect on 4070 ibs?
if u done this why we bather to buy mobile reflexes???
Top
sputniki
yes they do!
  • Quote
Post by sputniki » 14 Apr 2010 05:21
Konstantinos.E wrote:i have never seen siemens dect working on alcatel ibs.
Yes they are and not only at this location. You have to change GAP-Profile to "enhanced" (for hold/transfer functionality) but we had never such issues which Gigaset-Handsets but with one Mobile Reflexes 200 at another installation. That specific problem was solved by change of one IBS which was running wild after a while. But in the actual case there are no roaming/interconnection problems visible at monitoring mode of the Mobile Reflexes.
Konstantinos.E wrote:if u done this why we bather to buy mobile reflexes???
I would prefer this too but it's not easy to aver the type of handset as source of the problems. It has worked for three years fine. Nothing has changed since them (they have OXO Release 4.10 something).
BTW: the Alcatel handsets costs the fourth of the Gigasets and bring effectivly only phonebook an mailbox features to the client (and he don't us this).
Top
Konstantinos.E
  • Quote
Post by Konstantinos.E » 15 Apr 2010 04:02
That is cool.i i didnt knew that.I will try it to the lab but i fave a few questions.
1)The gap reg is the same with reflexes?
2)The gap profile is located inside siemens gigaset settings?
i am trying to find smthg in the omc but i cant.
thanks
Top
sputniki
DECT/GAP-Registration
  • Quote
Post by sputniki » 15 Apr 2010 10:41
Konstantinos.E wrote:That is cool.i i didnt knew that.I will try it to the lab but i fave a few questions.
thanks
1) yes, of course
2) no, you have to change this while registration is done in OMC. If you select the the user (left) and the (new) handsets IPUI-N (right field in OMC-registration-window) you see normally "GAP Basic-Mode" and now you should click the "Change Modus"-Button on the right. This is all described in chapter 5.1 of the OXO Expertdoku... (5.1 DECT and 5.1.1.4.1 Configuration)
3) OMC->Users/Stations->GAP Reg. - same as usually...
Try it! Maybe there is a second tricky thing to do. I remember that you can configure what key on the handset is used for transfer/hold and some other actions. But I don't remember if this is necessary or where it was done...
Top
Konstantinos.E
  • Quote
Post by Konstantinos.E » 15 Apr 2010 15:10
I will for sure :)
thnx for your reply !
Top
sputniki
Eco dect
  • Quote
Post by sputniki » 21 Apr 2010 02:41
It seems to be a problem caused by ECO-DECT enabled handsets. Probably with only a couple of firmware versions - but nevertheless the Gigaset-ones are now out of the run... Sadly...
Top
houseworxx
Re: GAP compatible DECT-Phones and lost connection?
  • Quote
Post by houseworxx » 05 Jul 2011 17:29
We have the same problems at a customer with 4 OXO's and over 100 Gigaset Handsets.
With Gigaset SL1,SL55,SL56 we had no problems, but since we take the newer SL37H, we have only with some handsets sometimes the problems of no incomming calls, connection fails for a few seconds and outgoing calls work sometimes only after a second try.
We swaped 4 of the SL37H Handsets against the new SL400H and it seems that the SL400H works fine. Since now we had no error report from our customer.
Top
dasw127
  • Quote
Post by dasw127 » 24 Aug 2011 06:11
Hello!
I have similiar problems with my Siemens Gigasets working in my Alcatel OmniPCX IBS system. Today I was trying to worki with A580 model and I must admit, that this is the worst case I've ever have. More than half of tries to make a connection ends in losing connection to IBS.
Does anyone know which Gigasets work fine? I mean different than SL400H? Or maybe DECT telephones from another manufacturer work better than Gigasets?
It's very annoying to me, because buying new Gigaset is somehow a lottery - will it work or will not? Many years ago I was using 4019 Classics (basic mode) and Comforts (enhanced mode) absolutely without problems.
Please give me advice.
Kind regards
Dariusz Wojciechowski
Top
jancek
  • Quote
Post by jancek » 21 Oct 2011 10:31
Hello, seems we have the same problem. We have detected problems with Gigaset E490 GAP phones on OXO systems. No incoming calls possible, set frozen. If you put out the batteries and switch it on again everythiing is OK for some time. Or if you unusign and sign in again through GAP registration. But what is the solution??? Did anyone contact Gigaset support? Or is it possible to upgrade firmware on theese phones and how to do it? Please help. Thanks.
Jan Mackovic
Top
  • Print view
Return to “PWT/DECT System”
Jump to
  • General topics
  • ↳   Talk to the admins
  • ↳   GENERAL
  • ↳   Outside World
  • ↳   PARTS
  • ↳   Pre-Sales
  • ↳   JOBS
  • ↳   Remote assistance contracts
  • ↳   Actis
  • ↳   Equipement Pictures
  • ↳   OT/OXE/OXO FEATURES REQUESTS
  • ↳   Lucent Technologies
  • IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
  • ↳   Beginner's questions about the Crystal Hardware
  • ↳   Beginner's questions about the Common Hardware
  • ↳   Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
  • ↳   Beginner's questions about the OmniPCX OFFICE
  • VOICE - Documentation
  • ↳   OXE (Crystal / Common) - System Documentation
  • ↳   4760
  • ↳   OXO - System Documentation
  • ↳   Documentation
  • VOICE - OXE (OmniPCX Enterprise)
  • ↳   Shelf
  • ↳   Media Gateway
  • ↳   PWT/DECT System
  • ↳   System
  • ↳   Translator
  • ↳   Classes of Services
  • ↳   Attendant
  • ↳   Users
  • ↳   Users by profile
  • ↳   Set Profile
  • ↳   Groups
  • ↳   Speed Dialing
  • ↳   Phone Book
  • ↳   Entities
  • ↳   Trunk Groups
  • ↳   External Services
  • ↳   Inter-Node Links
  • ↳   X25
  • ↳   Data
  • ↳   Application
  • ↳   Specific Telephone Services
  • ↳   ATM
  • ↳   Event Routing Discriminator
  • ↳   Security and Access Control
  • ↳   IP
  • ↳   SIP
  • ↳   DHCP Configuration
  • ↳   Alcatel-Lucent Series 8&9
  • ↳   SIP Extension
  • ↳   Encryption
  • ↳   Passive Communication Server
  • ↳   SNMP Configuration
  • VOICE - OXE - Common topics
  • ↳   MAIN
  • ↳   ACTIS
  • ↳   Asterisk
  • ↳   Boards
  • ↳   Bugs & Security issues
  • ↳   Equipment Pictures
  • ↳   Feature Request
  • ↳   H323 / Sip
  • ↳   IP / VoIP
  • ↳   IP SECURITY / ENCRYPTION (Thales)
  • ↳   ipTouch (40x8) issues and tricks
  • ↳   Linux tricks
  • ↳   MOH
  • ↳   ON SITE TROUBLES
  • ↳   Phones
  • ↳   Sipfoundry
  • ↳   Software Loading
  • ↳   Swinst
  • ↳   System Hacking
  • ↳   Traces
  • ↳   Usefull commands
  • ↳   Voice Guides
  • ↳   VMWARE
  • ↳   Wireless configuration and sets
  • VOICE - OpenTouch
  • ↳   MAIN
  • ↳   OTEC - OpenTouch Enterprise Cloud
  • ↳   OTBE - OpenTouch Business Edition
  • ↳   OTMS - OpenTouch Multimedia Services
  • ↳   OTSBC - OpenTouch Session Border Controller
  • ↳   OTNS - OpenTouch Notification Service
  • ↳   OTMC - OpenTouch Message Center
  • ↳   OTFC - OpenTouch Fax Center
  • ↳   OpenTouch Conversation
  • ↳   Smart Guest Applications
  • VOICE - BiCS
  • ↳   MAIN
  • VOICE - OXO
  • ↳   MAIN
  • ↳   Configuration
  • ↳   42xx Systems
  • ↳   Networking
  • ↳   H323 / IP / Pimphony
  • ↳   Internet and related
  • ↳   Applications
  • ↳   Hotel mode
  • ↳   DECT
  • ↳   Hardware
  • VOICE - Omni Suite
  • ↳   OmniTouch 8400 Instant Communication Suite
  • ↳   OmniTouch 8410 Instant Communication Web Services
  • ↳   OmniTouch 8440 Messaging Software
  • ↳   OmniTouch 8450 Fax Software
  • ↳   OmniTouch 8460 Advanced Communication Server
  • ↳   OmniTouch 8464 Meet-me Audio Conference Bridge
  • ↳   OmniTouch 8660 My Teamwork Conferencing and Collaboration
  • ↳   OmniTouch 8670 Automated Message Delivery System
  • ↳   OmniTouch Contact Center Standard Edition
  • ↳   OmniTouch Contact Center Premium Edition
  • VOICE - Applications
  • ↳   AECS - Alcatel Extended Communication Server
  • ↳   Alcatel OpenTouch Customer Service
  • ↳   Aviso
  • ↳   Call Center SoftPanel (ALU ProServices)
  • ↳   CCD / CCS / CCIVR
  • ↳   Free Desktop
  • ↳   GENESYS
  • ↳   Hotel / Hospital
  • ↳   Ip Desktop Softphone
  • ↳   IpTouch Phones XML Applications
  • ↳   MSAD
  • ↳   MyIC (My Instant Communicator)
  • ↳   My Messaging / IMAP
  • ↳   My Teamwork (ex-eDial)
  • ↳   OmniPCX Record
  • ↳   OmniVista 4760
  • ↳   OmniVista 8770
  • ↳   OTUC
  • ↳   PREMIUM / GCE
  • ↳   Rainbow
  • ↳   Ubiquity
  • ↳   ENS - Emergency Notification Server
  • ↳   VNA - Visual Notification Assistant
  • ↳   VAA - Visual Auto Attendant
  • ↳   VitalSuite
  • ↳   VitalQIP
  • ↳   Voicemail (46x5)
  • ↳   XML Presentation Server & TAPI Server
  • ↳   4980 - WebSoftPhone
  • ↳   4625 Interactive Voice Response
  • VOICE - Third Party Applications
  • ↳   AGITO NETWORKS
  • ↳   AUDIOCODES
  • ↳   ASTERISK
  • ↳   AVST
  • ↳   CISCO
  • ↳   NGINX
  • ↳   NICE
  • ↳   Notification Systems
  • ↳   OAK
  • ↳   SOURCE TECH
  • ↳   systel
  • ↳   IP Touch apps
  • ↳   Click2Dial
  • ↳   MYIC apps
  • Alcatel Unleashed tools, documentations, and misc files...
  • ↳   DIALER
  • ↳   VM_BACKUP
  • ↳   ipview analyzer
  • ↳   "Home Made" documentations
  • ↳   Alcatel Misc Documentation
  • ↳   infocollect
  • ↳   motview
  • ↳   Other Alcatel-Lucent tools
  • ↳   OFFICIAL TC's
  • Developer's corner
  • ↳   AHL / OHL
  • ↳   Alarming, Notification & Location
  • ↳   CCTI / CCA
  • ↳   CSTA
  • ↳   My IC Phone
  • ↳   My IP Touch Service for Enterprise
  • ↳   O2G
  • ↳   OmniVista 8770 User Provisioning
  • ↳   SIP
  • ↳   TAPI
  • ↳   TSAPI
  • ↳   Web Services
  • Alcatel Data Equipment
  • ↳   Security
  • ↳   OmniAccess 3500 Nonstop Laptop Guardian
  • ↳   Mobility
  • ↳   OmniAccess WLAN Switching Systems
  • ↳   OmniAccess WLAN 4302
  • ↳   OmniAccess Wireless Access Points 41
  • ↳   OmniAccess Wireless Access Points 65
  • ↳   OmniAccess Wireless Access Points 60/61/70
  • ↳   OmniAccess Wireless Access Points 80M
  • ↳   Mobile IP Phones
  • ↳   OmniAccess Devices
  • ↳   OmniAccess 5780
  • ↳   OmniAccess 5740
  • ↳   OmniAccess 5510
  • ↳   Network Management
  • ↳   Omnivista
  • ↳   Omnivista Mobility Manager
  • DATA - Documentation
  • ↳   Technical papers
  • ↳   Troubleshooting guides
  • DATA - Lan Switching
  • ↳   OmniSwitch 10k
  • ↳   OmniSwitch 9900
  • ↳   OmniSwitch 9000 / 9000E
  • ↳   OmniSwitch 6900
  • ↳   OmniSwitch 6865
  • ↳   OmniSwitch 6860 / 6860E
  • ↳   OmniSwitch 6855
  • ↳   OmniSwitch 6850 / 6850E
  • ↳   OmniSwitch 6560
  • ↳   OmniSwitch 6465
  • ↳   OmniSwitch 6450
  • ↳   OmniSwitch 6400
  • ↳   OmniSwitch 6360
  • ↳   OmniSwitch 6350
  • ↳   OmniSwitch 6250
  • ↳   OmniSwitch 2220
  • ↳   OmniSwitch 2260 / 2360
  • ↳   Legacy Devices (OS4024, XOS, OmniCore)
  • ↳   OmniSwitch 6600 / 7000 / 8800
  • ↳   OmniSwitch 6800
  • ↳   OmniStack LS 6200
  • ↳   Misc
  • DATA - WLAN, Mobility and WAN
  • ↳   OmniAccess WLAN Switching Systems (OEM)
  • ↳   Mobile IPTouch Phones (MIPT)
  • ↳   OmniAccess Stellar Express
  • ↳   OmniAccess Stellar Enterprise
  • ↳   Brick VPN Firewall
  • ↳   OmniAccess 5740/5780
  • ↳   OmniAccess ESR 5720
  • ↳   OmniAccess 5510
  • DATA - Network Management
  • ↳   OmniVIsta 3600 Air Manager
  • ↳   OmniVista 2500 v4.x
  • ↳   OmniVista 2500 v3.5
  • ↳   OmniVista 2500/2700 v3.4 and older
  • ↳   OmniVista Cirrus
  • ↳   Alcatel Quarantine Manager
  • ↳   Fortigate Security
  • DATA - Service Provider
  • ↳   5520 ASAM
  • ↳   5620 SAM
  • ↳   5650 CPAM
  • ↳   5670 RAM
  • ↳   5750 SSC
  • ↳   7210 SAS
  • ↳   7360 ISAM
  • ↳   7450 ESS
  • ↳   7450 Ethernet Service Switch
  • ↳   7750 Service Router
  • ↳   7705 SAR
  • ↳   7750 SR
  • Home Board index
  • All times are UTC-04:00
  • Delete cookies
Powered by phpBB® Forum Software © phpBB Limited
Privacy | Terms
Creative Commons License
AlcatelUnleashed is licensed under a Creative Commons Attribution-NonCommercial-NoDerivatives 4.0 International License.
AlcatelUnleashed is NOT affiliated with or endorsed by Alcatel-Lucent nor Alcatel-Lucent Enterprise.
CONTACT US
