GD lost of IP config
Locked
Split
Post by Split »
Hi everyone,
yesterday two GD´s are lost there ip config may be at same time. after reboot of the GD i get the folling message on the V24 port :
Disk Remounted
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
/dev/fla: clean, 130/30360 files, 13394/121396 blocks
/dev/fla on /mnt/flash type ext2 (rw)
Set initial public keys
md5sum: /mnt/flash/local/ifcfg-eth0.md5: no properly formatted MD5 checksum lines found
md5sum: /mnt/flash/.local/ifcfg-eth0.md5: no properly formatted MD5 checksum lines found
Warning! No ip configuration found, need to build it
/mnt/flash/local/startup.cfg: OK
Find startup configuration in /mnt/flash/local/
Reading of configuration in flash finished
Initializing random number generator
Generate 4096 bits
INIT: Entering runlevel: 3
Trying to map the io space of the board(=1). Wait 10 sec...
Compression daughter board type [MADA]
mada_3 DSP daughter board
e-MGD version 44.8.1
Media Gateway Software R9.0 loading ...
No password file found - using default password list
==> Configuration file not found - launching mgconfig tool: <==
backup config file not available...
Welcome to the GD IP configuration tool
MAC address 00809Fxxxxxx
1. Startup mode Dynamic
IP address 0.0.0.0 (Dynamic allocation)
Netmask 0.0.0.0 (Dynamic allocation)
Gateway address 0.0.0.0 (Dynamic allocation)
TFTP server address 0.0.0.0 (Dynamic allocation)
CS role address 0.0.0.0 (Dynamic allocation)
CS redundancy role address 0.0.0.0 (Dynamic allocation)
7. Crystal number (Dynamic allocation- Refer mgr)
8. IP QoS menu
9. BACKUP menu
10. Duplex and speed mode menu
11. Download binaries timeout 1200
Passive CS address 0.0.0.0 (Dynamic allocation)
13. Security function
14. Encryption
0. Exit
i´m reconfig the ip and it works again. There are a TC0918-ed03 where this issue is explain. The TC says folling about CORRECTION:
The fix (GD binary) is at least in following versions:
R8.0 G1.302.6.c
G1.302.7
43.8
the customer system works on R9.0 patch 24 and the binary version of GD is 44.8.1 i think it musst be fixed
Has anybody the same experience in R9.0 with lost ip config ?
Read TC 918 (GD LOSES ITS IP PARAMETERS)
From this TC
To prevent the GD losing its IP parameter, the following procedure should be used for each GD (after re-entering IP parameters):
Log as root on the GD (using su – command).
Use the "save_ifcfgeth0" command.
Locked
Return to “Media Gateway”
