Hi, i have installed/imported auto attendant greeting and need help how to assign outside lines/Incoming calls through PSTN to hit auto attendant..I am not able to assign how to setup that incoming calls should go to auto attendant..can somebosy guide how to assign all incoming calls to go to auto attendant?? I mean from which menu/Tab??
Attached are some screen captures of OXO AA for reference.
Line assignment to AA
picasso
GriMM
hi picasso
there is an option in DDI number modification Table in which you can setup your
DDI number with the number of the virtual terminal if you use a DDI
if you have a analog trunk, select your analog access on external lines. After
you need select call distribution and enter the virtual terminal number.
good look
good look
elkiwi
Hi picasso
First of all you have to create a virtual extension with dynamic diversion to mailbox. Then if you have analogue lines you have to go to External Lines --> List of Accesses and in call distribution of all the lines that you want (individually) put the virtual extension in destination number.
In case you have ISDN lines you have to translate them in public numbering plan.
regards.
regards.
picasso
picasso
elkiwi
