SLI16 Not ringing
afeef
SLI16 Not ringing
OXE Certified Engineers
Alcatel Common Hardware R9.0
Can someone please explain me the flowing problem?
we have 2 shelfs, all analog extensions ringing in shelf 2, but all analog extensions in shelf 3 not ringing.
we have replaced the cards. when we insert not ringing card in shelf 2 it's ringing, again when insert same card in shelf 3 it's not ringing.
highly appreciate your suggestion.
Afeef
Afeef
- Konstantinos.E
1. connect through serial in the gd and ga boards and and see if there is any incident.
2.they don't ring in all shelf's or in the same shelf ring normally ?
3 .telephone facility allows to ring?
4.cards are in service?if yes try outserv and inserv commands one by one.
5.try rstclp
6.there is a possibility that the back plane or converter of the shelf is damaged.
7.if u put for example ua card are they ringing?
hope it helps.
5.try rstclp
hope it helps.
- Konstantinos.E
JoelO
I had the exact same problem a year ago. SLI in shelf 13 would not ring phone but you could pickup and answer if you new when the call was coming in. I moved board to shellf 12 and it worked perfectly. I re flashed the GD in shelf 12 but still would not work. I installed a new shelf 13 and same board worked perfectly. Bad shelf.
afeef
All Engineers, thank you very muck for your valuable comments.
Murraya, no power supply in these shelf, this is -48 DC power .
Konstantinos.E, I have check all your points looks fine and all UA sets ring perfectly. Yes. This system configure by Actis.
JoelO, at the moment we don’t have new shelf, so we will try to get another shelf.
Oldboy, yes, Oldboy set is not ringing but we pickup the handset we can speak with caller party.
Vad, as I mansions before 2 shelf running with -48 Walt DC with mail rectifier.
Afeef
Afeef
afeef
