Hello...
i use usb converter to connect alcatel 4200 pcx ı have no problem..
but when ı tryıng to take backup from alcatel 4200 pbx;
ı' ve problem with pbx and ı cant take backup from pcx
can anybody help me ?
thanks in advice...
USB backup problem
Re: USB backup problem
Right i had the same problem using usb to serial interface
I solved it by connecting via ISDN interface (locally if possible).
But sometimes indeed it helps to switch zmodem off.
