Question about QOS rules in 6850
rjmeredeth
Post by rjmeredeth »
Can anyone tell me the difference between the active and enforcing columns in rule statistics under policies. All of my rules are active but not enforcing. Also my matches and packet count columns show a number followed by a zero in parenthesis. I assume the first number is the number of matched packets, but i have no idea what the zero is. I feel I'm probably missing something elemental, but i can't figure out what it is.
Name | Enabled | Matches | Enforced |Active | Count Type | Packet Count | Byte Count |Excess Packet Count | Excess Byte Count
rule1 | Yes |9773384 (0) | No | Yes | Packets | 9773384 (0) | 0 | 0 | 0
Thanks!
Robb
cedric1
Post by cedric1 »
can you put complete output with command you use
did you make a "qos apply" after rule config
only after qos apply is the rule enforced by the switch
Cedric
rjmeredeth
actually, I configured the rules with Policyview QOS in Omnivista. I'll try a qos apply and see if that changes anything.
Thanks!
Robb
rjmeredeth
This is the screen I had a question about. It's under Policy -> Statistics -> Rules. It may be perfectly normal. I've just started playing around with policyview, so i'm not sure what the stats page should look like.
cedric1
Post by cedric1 »
hello
after some tests it seems that your rule is active and working.
Don't care about enforced value
(0) in matche, don't care about it, the other value is important about packet match.
rjmeredeth
Thanks so much for your help!
