ring after any activity on ANALOG set with CLIP activated
OXE_4400
Post by OXE_4400 »
I have problem when activate CLIP feature on analog set. Set shortly rings after any activity: incoming, outgoing call, even after off hook/on hook. OXE SW R9.1 i1.605.13d ( newest).
Set shows calling number normally, but problem exist even after simple off hook without dialing. Set always rings for ~1-2 sec after on hook.
Message LED function deactivated as written in OXE docs. Everything is keeped in standard way for Europe:
SYSTEM/TONE DETECTOR/DSP PARAMETERS/ADDITIONAL PARAMETER No.1 : 1 ( ETSI).
Protocol type for CLIP: Between two ringing tones.
Display Compatibility of CLIP Set: ASCII.
Its mentioned in docs timers 319, 320 with values 7 and 2,5 sec. Tried to make 1sec, restarted SLI16 boards, no difference.
Wasn't possibility to restart OXE.
Eliott
Post by Eliott »
this is a known issue and there are several ways to fix it.
First I need to know if the Hardware you are using is only SLI.
The parameters are different for SLI and Z32.
In board choose "Between two ringing tones"
My first suggestion for SLI/MIX is:
-Change the System timers 319 and 320 to 2.
-Set Shelf - Board - SLI position:
Send Init Dynamic Msg = TRUE
Param By Default = FALSE
-Set the following Dynamic init parameters (Go down in mgr) for the board:
P20 = 2
P21 = 0
P22 = 15
P23 = 0
P24 = 2
P25 = 0
P26 =22
P27 = 1
-Reset the SLI
Before you change P20-27 check, if they are all set to 255.
If now, choose P10 to P17 or select from P30 to P37.
You need 8 bytes which are currently not used.
Man
Post by Man »
Yeah
I have tried this and it works.....
firekat123
Post by firekat123 »
i have tested this too.
it works fi9
airwolf
Re: ring after any activity on ANALOG set with CLIP activate
Post by airwolf »
Works on 7.1 as well
lbanias
Re: ring after any activity on ANALOG set with CLIP activated
Post by lbanias »
At R11.0.1-k1.520-29-e with the above parameters set up the analog sets still ring (ringer) twice when the APA8 is set with "Between two ringing tones". With ''After a short ringing tone'' when a user on-hooks and off-hooks quickly(or flashes without any active call) after 1-2 sec he can hear once a buzz tone (but this time only on handset speaker), but it does not affect dialling a new number. With ''After a dual tone signal'' he still hears a quick tone(less perceptible) when he flashes 2-3 times, but this is the best setup. Even if he flashes once it's okay. But the dynamic init parameters modified does not seem to have any effect, if I revert to Default Parameters the behaviour is the same. Maybe the System timers 319, 320 do something. I am not sure that this outside call flash has anything to do with my modified flash settings (between 5 and 20). This never happens if I deactivate CLIP on analog sets. Where does this tones/rings come?
filmil
Post by filmil »
Doesn't work for SLI16-2 on OXE 11.0.
Works for SLI16-1 (on OXE 7.0 as well as on OXE 11.0).
Does anyone know correct set of Dynamic init parameters for SLI16-2?
This set of Dynamic init parameters works for SLI16-1 only:
>P20 = 2
>P21 = 0
>P22 = 15
>P23 = 0
>P24 = 2
>P25 = 0
>P26 =22
>P27 = 1
Regards!
JoseFaura
Post by JoseFaura »
As Filmil asks.
Does anyone know how to fix the CLIP failure for the SLI2? The proposed solution only works for me in MIX and SLI boards.
Thank you
fery_s
Post by fery_s »
JoseFaura wrote: 24 Apr 2018 10:48 As Filmil asks.
Thank you
for SLI-2 just change this 2 parameters:
P0=3
P1=2
Return to “Users”
