Omni PCX Enterpise PC installer, help
shmiga
Post by shmiga »
Would you please send me Omni PCX Enterprise PC installer for R 9.0, if you can. Please and thanks a lot!
jasic
Post by jasic »
It's a part of the Software.
shmiga
Post by shmiga »
I already have this installer, but don t know that it is same for R7.1 and for R9.0 ? Please if you can explane me, thank s you.
freedom
Post by freedom »
Just have a look at the main package: \pcmao\boot_res\pcinstaller directory
shmiga
Post by shmiga »
Ok, I'm see what you say me and V2.21 is current. My question is: may I with this version to do reinstalation of R9.0 system?
freedom
Post by freedom »
You can use your current version if you use the same CPU.
If you want to load the new CS-2, you need the newest PC Installer.
Eliott
Post by Eliott »
Current Version is 2.26
Corrections since 2.21:
-------------------- journal : version 2.26 ----------------------------
RA crms00197834 : NGP PC Installer - INTIP3 Picklist NOK
Abstract: Do the desired modifications for the INTIP3 picklist to display the required version number
-------------------- journal : version 2.25 ----------------------------
RA crms00182355 : NGP PC Installer
Abstract:Make Enhance PC installer to support with GD3,INTIP3A,INTIP3B,GA3 boards
RA crms00043284 : Linux 55.0: Installaation Complete Not OK
Abstract:remove : Linux+call handling"/"Reload Linux" menu in PC installer.
-------------------- journal : version 2.24 ----------------------------
RA crms00159859 : Add CS-2 to the pick list
Abstract: Addition of CS-2 to the dropdown list and generation of of the
dhcpd.conf file for the requested configuration.
-------------------- journal : version 2.23 ----------------------------
XTSce98758 K2: Add a pseudo country 'k2' in picklist
Abstract: add k2 to pc_installer tel pick list for K2 project
XTSce95263 Change company name in all screens ( Alcatel => Alcatel-Lucent )
Abstract: change Alcatel to Alcatel-lucent in pc install images
-------------------- journal : version 2.22 ----------------------------
XTSce58201 PC Installer : Progression bar when reloading Linux
Abstract: improve progress bar display for complete install
XTSce72712 PC INSTALLER 2.21 Error windows displayed during complete installation of a version
Abstract: support static patch with release number > 10 and synamic patch install
XTSce77584 PC Installer V2.19 When uninstalling PC Installer . All the directory (and files above PC Installer is removed.
Abstract: avoid risk of erase directory not concerning by PC installer
shmiga
Post by shmiga »
I have 7 CPU with R7.1 and one more with R9.0. If I need newest version, where to download it? Thank you.
It comes in the main package when you download a release from the BPWS
Eliott
Post by Eliott »
It's also included in some static patches, frank.
Locked
Return to “Other Alcatel-Lucent tools”
